My '85 Cabby - getting closer to completion
1985 Karmann Cabriolet
Took a few photos of in the arches and underneath.
Behind the petrol cap hole.
Enjoy…
Not  much of an update but a sneak preview of my powdercoating:
I went to SprayBlast in High Wycombe and would highly recommend them. I had loads done including axle, shocks, springs, brackets, rad cowling, rocker/cam covers, brake parts, anti-roll bars etc etc in a mixture of gold with a sparkle and satin black. I expected it to cost a couple of hundred but it cost half that. Bargain!
Sounds a decent price ;) Underside is looking tidy too  :thumbs:
OK a little bit of an update (there will be a lot more in the coming month)
I've got a huge shopping list ready so will be going to VWH and Funkstar in just over a week to get it all. In the mean time I started to clean down the engine/gearbox further, as well as clean up the petrol tank, servo and brakes ready for a bit of paint. Had to do it all in a dimly lit garage seen as it's been daffodil it down all weekend.
Heres the tank after wire wheel and Kurust treatment:
This was the tank guard before I started:
Servo during strip down and wire wheel/sanding:
Kurust treatment:
Taking ages to dry coz it's so cold. Will spray them next week:
Gearbox cleaned up a bit:
Brake parts waiting for Kurust treatment:
Finished Kurusting then called it a day. Got 3 weeks off in a weeks time so I'm hoping to make lots of progress :)
You can see my gold beam in the last 2 pics :)
Loving the colour choices!
1985 Cabriolet GL
Black and gold with a bit of silver ;)
So, started on painting bits up:
Tank:
Then started on the engine. Here's the inlet prior to cleaning and painting:
And  all painted:
Quite happy how it turned out. Will decide if anything needs a 2nd coat later today.
looking good fella  :thumbs:
I've done a fair bit over the last few weeks so here's some pics (not many)
Tank shield fitted:
After a while the suspension was built up and rear axle put on. Then it was back on its feet for the first time in months:
More of the rear axle:
Will get more done over the next few weeks but currently replacing the cambelt and water pump on my mk4 1.8t. Got it replaced today but need to finish putting it back together after I ran out of light.
Tidy work  :thumbs:
Not seen rear lights like those before with grey smoke only, looks smart  :cool:
Yeah thought it was something a bit different. Not what I'd normally go for but they go really well with the paint.
Yeah same here, another body colour and they wouldn't work but that's nice and subtle on yours
Very cool.
Like the contrasting colours on the underside. I'm sure the MOT man will appreciate it  :lol:
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
I had to step back from the Mk1 for a while, mainly due to money, among other things. I've now started doing stuff again more frequently.  I've fitted a few little bits here and there but not spent a good few hours in the garage in a while, until yesterday.
Rear brakes are built up now and I've been trying to recon the fuel system. Here's how my pump and accumulator looked:
It took a lot of effort getting these apart:
After wire brushing and course sandpapering:
Primered:
Painted and lacquered:
I'm quite happy with how it's come out. I'm also doing my brake servo again as the finish using a brush was not good enough. I've got it to the stage that the accumulator was before painting but today I'm going to get some leveller to build up on it and then rub it down again to get a pretty decent finish. I'll post some more pictures when I get a chance.
Good transformation, nice job ;)
Did a bit more last night. Forgot to do the accumulator bracket:
Had to heat it up a lot to get the sheared bolt out and it's now painted, just need to lacquer it :)
I also rubbed down and used high build primer on the brake servo but the paint reacted really badly so I've left it over night to harden and will give it another go later. So my jobs today are to rub down the servo AGAIN and lacquer the accumulator bracket. I will also clean the servo with white spirit before I give it another layer of primer.
Also here's a shot of my driverside rear brakes built up:
I think I've finally got the mk1 bug again :D
Also, we have further cars in our vw family, another 2 polos and a Corrado as one polo goes to the scrapyard in the sky and another one goes in to a lock up for a bit after the cambelt tensioner went on it for a 3rd time in a row! oh well
Bit of progress…
After loads of priming and sanding I managed to get the servo looking like this:
Ive only got Matt Black at the moment so that's the lolour it's going:
Not the best finish but a lot better than it was. I need to laquer it now.
Accumulator bracket all done and back together:
Fuel pump foams and rubbers cleaned. Need a bracket now though:
And moved on to the master cylinder:
Master cylinder all cleaned up and painted with cylinder black. It's a satin finish so will look less glossy when dry:
Managed to snap a bolt in my steering column a couple of months ago so finally got started on removing that:
I went through a few drill bits and need to wait to get some more before I continue. Nightmare!
My main task now is to measure how long I want my fuel lines, hence why I've propped my metering head in the bay. I've also fitted the accumulator under the car and need to fit the other thing under there (not pump or accumulator) to see where the return line goes to. As far as I can see the supply line comes from the accumulator to the metering head and returns to where I've just described.
That's it for now but hopefully try and get some more done after work tomorrow.
Nice paintwork  :thumbs:
