Monkey's 1981 Golf GTi 1.6 project - rust is lighter than carbon fibre
X plate campaign edition Golf?
Do the BBS kit, you know you want to
Marketing Manager
Escort RS Turbo T3 with a slightly larger Sierra Cosworth 4x4 exhaust housing
Housing off and powder coating stripped
Luckily I had some spares left over from when I rebuilt the T3 on the escort. Put in a new compressor seal and cleaned the turbine blades, been rebuilt recently so didn't bother replacing the thrust bearing and bushings. Gave it a lick of paint along with the manifold and set up the preload on the actuator
1973 BMW 3.0CS "Helga"
1981 VW Golf GTi "Agolf"
1986 Ford Escort RS Turbo S2
1987 BMW M535i - 'Klaus'
Instagram: @ahmet_e9
Marketing Manager
MK1CRAZY YAHOOOOO!!!!!
Beeno said
Well done looks great. That poor brush has seen some better days though.
Many years left in that yet mate!
Marketing Manager
It's fiiiiine
Need to get cracking finishing off the front panel today, wished I'd just got a new one and be done with it!
Marketing Manager
Got a small section of the front panel and the headlight bowl done, paint was just too look for any high/low spots but it's come out quite well I think. Also picked up some sheet metal for any other bits than need doing.
Marketing Manager
Rear OS lower shock bolt wasn't budging, it'd turn a touch and spring back to its original position. Thought it was the arb, how wrong I was
Had to cut through the shock mount to get it off, old rubber smells nasty!!
Marketing Manager
New wing had the aerial hole fibreglassed over at some point and then opened again. Cut a piece to sit flush and welded, skim of filler and job done! Aerial will be getting relocated to the roof (I'll probably get a mk2/3 style bee sting)
Also found an old double action sander to get cracking on the many layers of paint on the bodykit. Ordered some rubber trim to fit as per original too.
I briefly thought of smooooving the whole kit onto the car too, but then I remembered it's not 1998 anymore
Marketing Manager
Beeno said
Good decision. Coming along great. And again quite a bit of elbow grease going into this project. That can only mean that its gonna come out looking great.
I hope so matey! Bit more work today and a bit more welding to the lower valance where dirt got in between the panel and the crossmember and just made it rust over the years.
Some filler on top to get it aligned with the wing.
And the bonnet was persuaded with a hammer to curve as when they hit it they didn't bother to curve the bonnet lip proper so it jutted out a few mm.
Stonechip and primer are next on the order list. Got some DSX raised top caps to drop the front down another 15mm too.
Marketing Manager
Also picked up some underseal, a litre of primer, stone chip and some thinner welding wire. Had a go with the 0.6mm wire and it's made a lot of difference, was trying to weld with 1mm before and it just kept blowing through the panels. Getting another genuine VW wing as mine has some rot on the bottom and the less welding there is to do the better.
Might make a start on the inner wing tomorrow. Want to get it all welded so I can then underseal it before I go to Uni on Sunday and fit the wings.
Marketing Manager
Nos.
Marketing Manager
Raised the back up another 15mm so now it doesn't gouge out the tyres when moving it about
Started cleaning out the interior as well. Need to ditch that equaliser
And last but not least, took off the a pillar trims as I could spy a small bubble and was quietly crapping myself that all the trapped water under there would've turned it all crispy. Result!
