Mellow Yellow 3.2ltr 24v Conversion
I still in shock over you want closer ratio feels like i'm running out of gear straight away…
Mellow Yellow 24v Conversion
Current Mk1's
1992 VW Citigolf CTi 1.8i (SA)
Previous MK1's
2006 VW Velociti 1.6i (UK)
1992 VW Mk1 Golf Clipper 1.8 carb (UK)
2000 VW Mk1 Citigolf Life 1.6i (SA)
1991 VW Mk1 Citigolf Sport 1.8 carb (SA)
1983 VW Golf Mk1 GTS 1.6 carb (SA)
Previous MK1's
Got the gearbox etch primed, black enamelled and output flanges painted. New input shaft seal and output shaft seals as well.
Now I wouldn't advise this manoeuvre with fresh paint and I'm not really sure it should be attempted without removing the entire engine. Dad and I tilted the engine on the drivers side mount. Bashed up the lower chassis leg where the tie rod passes through so had to repair that after everything was in.
Got the thing in eventually.
The 02j / 02a VR6 V5 bell housings are wider than the 5 speed bell housing so was catching the bolts on the casing .
Bit of sanding, priming and colour and all good again. Was pleased with the result in that tight area.
Last edit: by Rich.
Got exhaust on and back on the ground. Great news is it goes forward and backward but haven't had the chance to drive it as it's sorn at the mo. No unusual sounds which is great news .
FXTURE said
Top effort Rich .Will this be buzzing around my city soon ?. i'll still keep my eyes peeled ?.
Yes Mayor FXTURE I will be driving through your city .
I did last year, surprised you missed me as went past the Council offices a few times .
Got some new wheels .
Unfortunately my helper was sleeping on the job.
I think this will finish the look off, rear will go on as well. Just a mock up.
and this as a sump early warning detector .
Used stainless torx screws which I will paint black but they are all greased up. Fitment of the pattern spats was surprisingly good .
Can I ask where you got the arch trims, they look really good and I need a set.
Pistol said
Looking lovely, really suits the new wheels and in my opinion the original GTi arch spats look so much nicer against the yellow paintwork.
Thank you sir. The arch trims really do suit the colour scheme. I'm really pleased I went this direction.
I bought the arch trims from Mark at Classic VW a couple years ago and had them in storage but it looks like he is out of stock .
I'll get her out for better shots this week. Will get the duck bill on tomorrow .
Just love the wheels and spats too … awesome!!!
Mark at Classic VW said the part might need some fettling to fit and to shave it down.
The fit was questionable but with some file sander got it spot on .
