Mellow Yellow 3.2ltr 24v Conversion
Seam welded the gearbox mount for extra rigidity and tidied it up a bit on the engine mount side.
Last edit: by Rich.
I dug out my old Gti 256mm calipers with the special carriers that fit the mk1 hubs. Going to trial fit them to see whether they are a better fit with the wheels. Also nice to have a direct fit caliper than using an adapter.
Last edit: by Rich.
The Yellow Peril R32
gafo said
Great build mate , brave fella, was this car in golf mag? Previous owner a woman? Looks familiar well she had g60 in her yellow golf. Have g60 in my wagen love the sound although my cuz has vr6 in his mk2 equally nice sound ,funny he has v5 box in his golf and it's got better ratio than vr6 box so he reckons. Best of luck with the build, what are the brake carriers of by the way?
Nah not been in Golf mag and no the previous owner wasn't a woman. I put a G60 conversion in her, lasted for a year before I changed my mind and went R32 lol
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fthe-yellow-peril-G60
The brake carriers are from an early Scirocco I believe
Never got it rolling roaded, but hey it's not always about the figures, just how the car drives and it sure did that.gafo said
Had a read of your g60 build thread / money pit , I remember it well. Did u ever get it rolling roaded? Didn't see any figures, there some machine in g60 mode, also when r.j did the wiring loom are all the connectors included or is it just wiring ?
I got new connectors where possible and used the existing g60 ones where they were no longer available.
Welded in a bracket to mount the dual remote servo.
Now I can finish off the last bit of grinding and then the sand down begins
Last edit: by Rich.
That engine bay will look slick when finished
Keep up the good work, it's threads like this that keep us all motivated!
Stevieboy1107 said
Great work, really looking forward to watching this progress. Like you say there ain't much info or guidance out there on this conversion yet.
Cheers Stevie
starting to pick up momentum now, only managing to work on the car at the weekends but have some days booked off to speed up progress
Before:
Some heat gun and scrapping action:
Started removing the residue:
Finally got there
Thankfully no signs of rust and original floor:
Next going to sand it all down and get some epoxy primer on
Last edit: by Rich.
Chain and guides removed
Old bits
new bits on
Also started to remove the 5th gear from my CTN diesel box to go in the CDM Corrado box.
Tomorrow I will finish off the gearbox and start fitting the service parts to the engine
Last edit: by Rich.
Matt
Modified the alternator bracket so the air con section is removed for more clearance. Added a new diesel alternator with W terminal and mounted up the tensioner so i could trial fit the V belt. Success .
Last edit: by Rich.
Next I'm going to remove everything and paint the block and gearbox. Hoping for a trial fit week Friday.
The interior and exterior are on pause at the mo, need to check the radiator, fan assembly and oil cooler fit and the necessary brackets fabbed up before i touch the prep and paint.
Re:
Cheers Mattpazwaa said
Great work. Your floor looks in great condition
Matt
Sent from my Nexus 4 using Tapatalk
Last edit: by Rich.
