Mellow Yellow 3.2ltr 24v Conversion
Fitted a variable heater valve, it allows the coolant to flow in to the heater matrix in varying levels or being completely redirected to the engine.
Then trial fitted the air filter housing. It's a good fit and a change to the radiator support bracket will be a good place to get cool air in but Houston we have a problem.
The air box is sitting too high . I reckon I can change the first silicone over to a 15 degree bend lowering it quite a bit as I'm going to have bonnet fouling issues otherwise. One is on order.
Once the fitment has been sorted for the filter housing I need to heat protect wiring, bundle them and protect a few hot spots with all this.
That will finish the engine bay and on to the new exhaust and finish the brakes
I can wait out and see if I can get hold of a black one or change the coil covers to blue and possibly the elbow to the air box housing but I think that will also be a tricky one to find. What do you guys think?
Also played around with the brake fluid reservoir position. Just need to work out a good location. Might look for a prettier brake fluid reservoir with dual outlets.
Mellow Yellow 24v Conversion
Whip
/wip/
Noun - Car
/wip/
Noun - Car
the_whip said
Ha that's a bit ballsy for my liking
Mike 16vG60 said
Looks really neat! If it was me I’d look for a black version of the silicone hose, but having it all working with the blue one wouldn’t keep me awake at night. The positioning of the brake reservoir looks good in the last photo-with the air intake in place it fades into the background a bit. All in all very functional and clean in my opinion (much more so than my bay!) Great work.
Cheers chap, I just got an email from ash silicone to say they only do them in blue now. Can't find anyone who can make them black 15 degree and 83mm ID.
Can get 80mm and 89mm but that is far too small and large
the_whip said
Can you photoshop the coil covers as blue please
Last edit: by the_whip
Whip
/wip/
Noun - Car
/wip/
Noun - Car
the_whip said
Cheers chap.
I don't think that looks too bad. I think I'll make the change to blue coil covers as a nod to the R32 and if I can find a black silicone change it over.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
the_whip said
Red is obviously tempting, but blue and yellow are complimentary colours so very pleasing from a designer point of view:
Yes I agree. I looked at the prices of the coil covers and they are £70 from Germany for 6 pieces of plastic : O.
I forgot you can get non adhesive silicone repair tape in loads of different colours including black. I think I will give that a go and re wrap the surface. If it looks naff I can peel it off.
It's worth a shot as looks more OEM.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Rich. said
I just love the quality of the images you post. Spot on that man. This is probably one of my favorites of any recent ones you have posts.
That engine looks insane squeezed into that humble MK1 engine bay. Makes my TFSI engine look positively spacious
Ha it looked much smaller without all the stuff added. I guess most people go for a shaved bay look and compromise on brake servo, brake bar and the heater.Lhasa2008 said
I just love the quality of the images you post. Spot on that man. This is probably one of my favorites of any recent ones you have posts.Rich. said
I've managed to retain all the goodies but has made it a bit tighter at the back. Loads of room at the sides of the engine though.
Last edit: by Rich.
Started by removing the surface rust from my brake disc's. They were new on at the beginning of this never ending project and during the garage build where the car wasn't in a climate controlled building.
Broke out the Deox C, soaked them for 20 minutes and then cleaned and zinc primered.
Then sorted out the silicone hose. Really pleased with the finish. Bit shinier than the other silicone but will do the job for now.
And a teaser of the brake calipers
Last edit: by Rich.
Really? Brake servo?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Been using Bilt Hamber products and this for years. Normally leave it over night but it came off super quick. Always works brilliantly especially for old crusty calipers.the_whip said
"It will remove very heavy corrosion, but is safe to use on even the most delicate items"
Confused about your question? are you surprised people run without servos? I obviously have mine and a big one European LHD Golfs are lucky as servo off the brake pedals in the ideal position. Some people are crazy, I wouldn't run without one!
Last edit: by Rich.
It seemed like quite a bold claim, as though it wouldn't damage anything. So I was wondering if you could just submerge an entire brake servo without damaging the diaphragm etc.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
