Mellow Yellow 3.2ltr 24v Conversion
I now have 10 litres of super unleaded and tomorrow I will attempt a test start!
Wish me luck and should have a video of it running…. hopefully
The engine start was not an immediate success as I attempted to start yesterday and it was only running on a couple cylinders. I must admit I was very disappointed but did all the normal checks, fuel, spark, compression and everything was fine.
This morning I emailed Vince at Stealth racing and within minutes he was remote connected to my laptop running vag com and on the phone running me through things to check.
After a couple hours we got to the bottom of it and the issue was that 1 wire wasn't locked in to it's connector properly for the engine coolant temperature which upset it greatly. Re sat the connector and instead of the ecu thinking it was -45 degrees c lol it was reading the right temperature.
Then Vince created some diagrams on how to eliminate the SAI and EVAP error codes using relays and resistors as he said the engine won't enable the lambda's until these errors are cleared which should make it run even better.
I can't believe how generous he was to spare me time on a Saturday morning! I can't wait to take my car to him to have it tuned up The car is running no coolant or air filter at the mo so only run briefly but in the next week should be able to give you some nice exhaust noise
Mk1 Golf Audi A3 3.2 24v Start up - YouTube
Last edit: by Rich.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
WELL DONE
paceman said
Excellent - bet you are rightly well pleased with yourself after all the effort that has gone into it!
Over the moon but still a little bit more to do to get it finished. The current situation with the world has certainly got me to get my act in gear.
Noticed a few issues with my fuel system. The surge tank is the wrong way round. Just need to flip it. Just makes it trickier to get to fuel connections in it's current location.
Got the new clutch line which I have cut to length and got the ends on just needs a shorter banjo bolt which should come tomorrow.
Keep going.
Looking forward to seeing and hearing the completely finished article.
Bergie64 said
Well done Rich! I thing you are very happy of it after all the work you put in it.
Keep going.
madone_si said
congrats, big milestone. another step forwards driving it
Thanks guys I've had a few deviations on this journey such as the removal of the rain tray and then reattachment lolPistol said
Super build thread, proper home built resto. End result is looking amazing. And who'd have thought a Mk1 Golf could be remotely diagnosed using a laptop!!
Ecu is off to Toyotec to get the remaining codes removed including VSS and conversion to manual as the engine was from a DSG Audi.
Hoping to get the coolant system plumbed in this weekend plus have an electronic variable heater valve Honestly if anyone wants to attempt this build please don't hesitate to contact me. The most complex side of this build is the loom and ecu but there are plenty of talented people out there. Hummel did both himself! I wasn't brave enough I'm just hoping my Milltek classic 2.25" exhaust doesn't choke the engine too much :/
borednow said
Awesome!
Glad it started ok in the end
Personally I think it looks better with the 1400 16v in there and I think you should go back to that. Wouldn't take long
Nice work mate
Ian
Thanks mate lol
The 1400 was ok, nice noise but slow at 140bhp.
My Golf has now matured in to a cruiser. I'm sure 250bhp will be plenty to scare me if I can get it down.
Turbo in the future maybe
Im on board on that one! I have the same mind set, lets see for how long this can run without a turbo Unfortunately the rules in Denmark are insanely strict regarding car builds, so that would cost me another TÜV approval…
The Loom is not that big of a job, with a nice diagram it was very easy. For me the biggest issue with the engine conversion had to be the maaster clutch and gas pedal arrangement, had to do both over twice :O
Have to say iti again mate, this is an awesome build and the car looks really clean! You're putting alot of pressure on us to have the same build quality, or at least the same cleaness Keep up the good work!
borednow said
You're insane!!!!!!
The 150 from 1.4 is enough for me. My cahones obviously aren't up to the job!!
Ian
I'm sure you have 150bhp in each cahona (Is that singular) lol
Thanks Hummel.Hummel said
Im on board on that one! I have the same mind set, lets see for how long this can run without a turbo Unfortunately the rules in Denmark are insanely strict regarding car builds, so that would cost me another TÜV approval…Rich. said
Just been told my ecu has been coded and will be sent back. Sweet Finish the coolant system today me thinks.
Flipped the fuel system yesterday so the pump was at the lowest point. My bad
Got my ecu back so added a video with a bit of revving in lol
https://youtu.be/t8gYoAndRKs
I have got a new exhaust to replace the Miltek classic. A track slag in 2.5"
I've got to kick myself, I should've test fitted the SA brake bar with the heater. The heater output for the top hose was bang in the middle of the brake bar.
I created a brass plate which allowed the stock grommet and hoses to work. The back of the plate has edpm rubber stuck down with contact adhesive and 3 retaining bolts.
Much better now:
Fitted the variable heater valve, it allows the coolant to flow in to the heater matrix in varying levels or being completely redirected to the engine.
Then trial fitted the air filter housing. It's a good fit and a change to the radiator support bracket i made will have a good place to get cool air but Houston we have a problem.
The air box is sitting too high . I reckon I can change the first silicone over to a 15 degree bend lowering it quite a bit as I'm going to have bonnet fouling issues otherwise.
Once the fitment has been sorted for the filter housing I need to heat protect wiring, bundle them and protect a few hot spots with all this.
