Mellow Yellow 3.2ltr 24v Conversion
Which exhaust system do you plan ? Custom? I'm also doing a R32 swap and can't decide if the money is well spent on a Milltek.. ? I also have the Eurowise header.
Thank you I have a Miltek Classic exhaust which I will make up a joining section to the Eurowise header. The R32 has a stock bore of 2.5" for the Mk5 engine. Unfortunately the Miltek is 2.25".Hummel said
Insane build! Very impressive..
I will get it tuned by Stealth racing when it's running and will check on the dyno if it's choking the engine.
It was an expensive exhaust to start with and I like the look of it so will give it a go first and then get a custom one if necessary.
Well I , thought the R32 was 2.25" orginal but thats only the mk4 golf. My engine is a BUB from a Mk5.
I like the idea of a 2.25" since it will be an easier fit, but with the stock exhaust being 2.5" i think I will look for another system, maybe JETEX, thats is 2.5"…
Thats right Mk4 2.25" and mk5 2.5". I guess the stock R32 exhaust would be a lot more restrictive with catalytic convertors.Hummel said
Thanks for answering…
Hopefully having a straight through exhaust with 2 inline silencers and no cats which is shorter than a stock R32 should flow well even if it's 2.25", I hope
Last edit: by Rich.
Oh and I've had the 2.5" Jetex exhaust when the car had a G60 engine. Good exhaust and fits well but didn't like the tail pipe.
hope you get the house sorted soon enough so you can finish the car
DANBOY.
Mk1 Golf cabrio "Golf+ absolutely cabulous"
fresh 20vt rebuild well underway https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-old-white-cabby#post_1402754
Should be moving in several weeks time (fingers crossed).
Clearing the garage up for moving day and put the wings and bonnet roughly back on for transport. Pretty dusty at the mo, poor thing
Last edit: by Rich.
I'm doing a complete rebuild of the car so I'm doing a lot of body work at the mo but Iv got the motor and and a VR box ready.
I hope the move goes well bud and I can't wait for some more updates 👌
Last edit: by 77mk1_R32
Unfortunately I have a list of things to do first to the bungalow before I can have a proper play with the car. I have a loft conversion to organise and new kitchen before the wife will let me extend the garage.
I currently have an over sized single garage but the plan is to double the length once those bits are complete. I lack power to it as well which is a pain but nothing too difficult to sort out.
Bit of a pain to get it up the drive though, no steering column / steering wheel also didn't help the wheels were doing a snow plow because of no alignment.
Took an hour to winch it up 4 foot at a time, the neighbours were probably thinking what on earth.
Last edit: by Rich.
Sorry if it's been covered before but there are lots of pages to go back through. Which gearbox have you gone for? Is it a vr6 clutch & flywheel you are using?
The car looks great on steel wheels, I've decided that's the looks I want for mine.
Not quite yet. Just checking with the local planning department whether I can extend the garage. Should hear this week if it's permitted development. Building control has told me its exempt so all good Originally I got a V5 gearbox which has the correct bell housing but after talking to Vince at Stealth racing he said go for a Corrado VR6 gearbox as the V5 is too close ratio. I have fitted a diesel 5th gear from a CTN box to give me a nice cruising RPM. Yes VR6 flywheel and VR6 clutchSuper_ted said
Any more updates on this Rich? Loving the work so far.
Last edit: by Rich.
It appears I fall under permitted development so I can crack on when I like. Going to start the build of the garage late summer but in the mean time I have started organising the Golf in the Garage and sorting out the parts I need for quick access.
Will get a proposed illustration of the garage up tonight
Got my wheels out of hibernation as well and starting to find all the parts for the engine
Also removed the wings.
A nice surprise arrived today
Rear disc conversion kit from Heritage
Getting there now , because I've been allowed (by she who must be obeyed) to extend my garage first I had to prioritise the garden next.virus-zn said
The garage setup looks pretty neat mate. Glad you still working on this. Look forward to more updates
3 skips of earth and rubble later and a new retaining wall. Should be completely done in the next 2 weeks, just got a lawn and patio to lay I will then be completely focused on the Golf.
Last edit: by Rich.
Started building up the front of the block with an alloy crack pipe and Eurowise alloy thermostat housing. Fitted a new alternator in the top position of a modified accessory bracket.
