Mellow Yellow 3.2ltr 24v Conversion
Daytona said
Bergie64 said
Thank you you are so quick to answer!Rich. said
Thanks for the kind comment.Bergie64 said
Hello Rich just read all the 18 page of your post!
What a job I love it!I have question for you.I'm making a 3.2 swap into my scirocco MK1 and was asking myself about the length of the transmission axle, can you give me the size of the 2 axle you bought on eurowise?
Thank you so much
I must admit I'm not entirely sure how you effectively measure a drive shaft. Mine are designed for the 02a Corrado VR6 gearbox. I have measured them in a compressed state and have included pictures for reference. Take this with a pinch of salt though.
780mm for longest shaft and 460mm for shortest. I would reach out to the guys at retrofication as they make custom driveshafts for the conversion and may answer the question.
Your measure are good!
I use a BHE engine from a audi TT I bought in UK and a Corrado Vr6 gearbox code CHN!
I'm using epytec engine mount but they have drive shaft pretty expensive so I Tru to find a solution….
Nice work you did can't wait to see the end.
I suggest you contact Dave Mac propshafts in Coventry, https://www.google.com/url?q=https://davemacprops.co.uk/&sa=U&ved=2ahUKEwiSpoSCifzmAhVwQ0EAHSaTAWQQFjALegQIBxAB&usg=AOvVaw23GA6bKwq81Vrn0Hskecdw Dave is class leading in shafts and you will deffinately get custom shafts of the best quality.
Marcus.
Thanks man for the address but already find the shaft, need to order it now.
Rich. said
Got the suspension and wheels back on tonight and looks like i just need to lift the car a little bit more to slide the engine under on Saturday.
Going to give it a clean up tomorrow
So nice work man! definitely love it.
What are you using as wiring?and for the cluster?
Wiring loom has been converted by Eurowise and I'll use the stock cluster.
OK, can I have some details about the wiring and the stock cluster in private?
No damage to the new paint until….
I went to pull the engine crane away and one of the hoist hooks fell and dinged the chassis leg I should be able to spot repair it quite easily. Cellulose paint is quite forgiving like that fortunately.
Your ramps / jacks look pretty cool, what make are they?
G-Dog said
Paint repair looks good as new! Fustrating way to chip it it I bet!!
The ramps i got off ebay and made in the UK. I think they are a clone of the CJ Auto version.
Dug out the inlet manifold I had carefully stored away ready to fit at the weekend and this is what I found
I'm guessing the clear was put on too thick and perhaps not enough time between coats letting the clear dry for the solvents to escape.
Anyhow I've slowly sanded all the clear off, just need to give it a final go over with 600 grit wet and dry and then it will be ready for a fresh coat! A different colour this time
Spudfingers said
😳😳😳😳😳😳 my god this thread is brilliant!! Keep the updates coming I'm following this one now!!
Thanks chap, wasn't sure anyone was looking anymore except for the regulars as the post views haven't gone up since the website was down over Christmas. Is there a problem lhasadreams ?
Looking forward to some pics on your thread
Rich
Rich
I'am looking Rich can't wait to see what's going on.
Your work is a lot of inspiration for other people!
Website Manager
Rich
You are right, hadn't noticed. Looking into it now.
Keep the updates coming.
keep pics coming
lhasadreams said
You are right, hadn't noticed. Looking into it now.Rich. said
Thanks chap, wasn't sure anyone was looking anymore except for the regulars as the post views haven't gone up since the website was down over Christmas. Is there a problem lhasadreams ?Spudfingers said
Looking forward to some pics on your thread Cheers
Rich
Rich. said
Thanks guys for all the kind comments, I'll keep the updates coming
Keep going buddy 👍
