Mario
Mario
Mario
Mario
Mario
Mario
Mario
Few options
Go higher
Go lower
2mm spacer and change the camber out a bit
Stretch tyres 175 or similar.
Got to love an easy 'bolt out and bolt in' job aint ya>?
Ian
Mario
Check out Alloy Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Ian
Mario
Mario
Well not so about the timing belt though
I would take the spark plugs out and get hold of an endoscope or borescope to inspect the surface of the cylinders.
There's quite a bit of confusion whether it is a non interference engine as people have previously bent valves on the Corrado PG platform.
Good luck
Take this with a pinch of salt. I see you have a T4 bottom end. The flywheel position mark is on a PG flywheel which is aligned to the PG crank at TDC is viewable though the inspection hatch on a 02A or 02j gearbox
Last edit: by Rich.
Mario
Mario
Mario
Mario
Its a contentious subject and has been discussed many times. The bentley manual / VW suggests this is the case but even if you set it up with a straight edge from the head like I did your car should run either way as the difference is negligible.gafo said
Anyhoo when working off the camshaft timing marks on the inside of the camshaft with the single dot do I leave the rocker cover gasket on? Thanks
This is the guide: http://the-corrado.net/showthread.php?38512-Definitive-G60-Timing-Belt-Setting
Have you set the distributor correctly using the notch in the cover cap to TDC?
Have you checked compression after the belt snapped?
Good luck
Last edit: by Rich.
