Golf mk1 1.1 '80 full restoration project (Loads of pictures!)
Dangerous44Dave said
This is an awesome thread! thanks for showing the detailed bits of welding - has helped me get my head around a lot of what I need to get done! Keep up the good work
Did you buy the replacement metal for this bit or did you make it? … if the later … how did you get the same shape? I've been wondering how to get this section sorted.
Thank you!
We welded a straight piece of metal on the part we cut out of the sill (as you can see on the picture you quoted.
Then we welded a L shaped piece in place that we made from some sheet we got laying around. make sure to make this long enough so you can bend the side over so the rail of your sill looks the same all the way down the car.
After that's done, weld the floor panel you cut out, back in. (We cut it out so it's easier to weld and cut the rust out)
Finally clean up the welds and rail under the sill
I hope I made it a bit more clear, if not send me a pm
And resprayed the small metal brackets mounted onto the oil pump.
Once the oil pump was in place we mouted the timing belt sprocket and alternator pully.
We also gave the airdeflectors a look, they were beyond saving.
So we fabricated two out of a 1mm thick aluminum sheet, cut them out using metal sheers, gave them a quick sanding. Primer and satin black spraypaint to finish them of.
That's it for now. Hoping to finish the engine rebuild next week.
Hopefully we FINALLY get our freshly painted shell back!
Last edit: by D_Martijn
Re:
D_Martijn said
Been a while since I posted some updates
School started again so we have less time to work on the Golf Today we decided to paint the transmission after watson suggested to paint it
Before, all taped up.
After
Also bolted new studs on the cilinderhead
What paint did you use for the transmission?
We used Motip heat resistant paint in silver
Re:
Thanks. Looks like Dupli Color is the U.S. product line. Need to do some cleaning first.
watson said
Nice work Martijn. New air deflectors and painted gearbox looking good.
Thanks got the idea from you haha
Still no news on the shell
Indeed, we degreased ours and sandblasted it afterwards to get it fully cleaned
BajaScout said
Sand blasting. Haven't tried that yet. I have a compressor so maybe I should find a used blasting cabinet.
Make sure you compressor had a big enough air output or you'll have to wait a lot + it'll get super hot
Now we patiently wait when they finish the outside..
My Build Thread
AL_Mk1 said
Looking good!!!
Thank you!
Feels good to see it painted
We'll be busy the whole weekend
Thanks, all sandblasted and powder coated or painted + new seals and bushes!Hairyarse said
Ooo new stuff!! Looks good
I'm Martijn's brother by the way, also found my way to the mk1 forum!
Last edit: by JasperDemeulemeester
Also mounted a rear shock to see how it looked
Rubbadubdub said
this will be so mint by the time your finished, keep up the good work, cant wait to see it starting to come back together
Thank you!
We can't wait either haha
