GarytheGolf
GarytheGolf
It's quite a good classic VW show - a lot of aircoold too, so not your typical 'scene' show. You should enjoy it and the setting is beautiful!
It has taken me some time to finish of the rear seat. Got the sewing machine out over the last few week nights.
I am reasonably happy with it, though don't look too closely at the stitching. I was mortified to see a small area had separated at a seam when fitted to the seat foam. It required a bit of darning / repair, you can just see in the center of the picture.
Finally being attached to the seat back:
and finally into the car, the effect looks good which is what I was after.
Unfortunately the voltmeter supplied with my new gauges was dead as a dodo, hopefully I will get a replacement soon.
I also discovered that the front passenger window has detached from the window winder channel inside the door, so another job to do. The new window seals retained the glass as the window was wound down.
The car will be back on the road from April 1st after being SORN'd for the winter.
Yesterday and today I stripped and serviced a 36TLP Weber carb which I obtained a few years ago. It was previously fitted to a golf.
Over time I have managed to get the proper VW choke cable, choke light and the full installation kit with instructions.
A few pictures, before I started, I had previously given it an external clean. These photos came in useful when it came to assembly.
References: The Haynes Manual and the installation guide.
Service kit: Should have taken a photo here, the kit included the majority of gaskets seals and replaceable components. I was missing one seal and a float pin, both of which I reused.
Stripping the carb: a bit mucky, also having not been used for a while, very dry:
Accelerator pump
Cleaning:
During assembly, I checked all the gaps and settings. The Haynes manual, is quite informative, but does not list the Weber for the Golf.
However, most of the settings apart from the main jet are the same or within the same tolerances.
Assembled / Finished:
I had trouble with the accelerator pump jet, it was blocked, managed to clear it with carb cleaner.
Hopefully I will be able to install the Weber in the coming weeks.
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=show-meet-pictures-and_2%2Fsimply-vw-26-june-2016
I decided to do a bit of titivating, take it for a drive and take some photos that are not outside my garage!:
Last edit: by Malcolm
GarytheGolf
Posted at work…
That exactly what I have been doing today.
I still have a few jobs I would like to do, but they can wait.
Malcolm
What an outstanding restoration and many thanks for taking the time and effort to create such a comprehensive blog! Proving a HUGE help in my own restoration!
Couple of questions if you don't mind:
I note on your rear axle reassembly you used
1. "Duralac jointing compound" - not something I have come across and can't find anyone else that has used it - why did you use it??????
2. What silver paint did you use on items such as the alternator, starter motor etc????
3. What did you use for the "cadmium" yellow passivated parts like nuts/bolts, alternator bracket etc?
Look forward to your reply.
http://intek-uk.com/duralac_compound_dtd-369b.html
2. Simoniz Silver enamel paint, likewise gloss or satin black for other parts.
3. A bit of a cheat: Smooth Hammerite Gold, touched up where required or completely painted after preparation (soaking in DEOX C or Gel from Bilt Hamber).
http://www.bilthamber.com/corrosion-protection-and-rust-treatments/
Black items were prepared (DEOX C or Gel), then painted in POR-15 (Frost Products), then painted in either satin or gloss black enamel.
http://www.por15.com/
Hope this helps.
Malcolm said
I am considering replacing my Pierburg IB3. On occasions it can be a bit temperamental when cold starting with the autochoke. It's fine when warmed up.
Accelerator pump
Cleaning:
Yesterday I replaced my troublesome Pierberg 2E2 in my Mk2 with a progressive weber kit. It was very straightforward to fit straight out of the box. Its seems very well engineered as well only needing a few tweeks, and most importantly, the car runs sweetly on it, far better than before. Whilst the original carb is considerably more fancy, to my mind, it was simply more to go wrong, and I was constantly chasing my tail trying to fix it. Not bothered by loosing the originality one bit!
GarytheGolf
Posted at work…
Re the anti roll bars, I suspect yes, however there might have been a change in the early production cars. I will have a look at my parts catalogue and see. I''ll let you know.
So the Simoniz SILVER paint.
Just to confirm, I used Simoniz Engine enamel in silver, black satin or gloss for the engine.
