GarytheGolf
GarytheGolf
Nice to see the MK6 too
Sourcing the correct form of chrome moulding is difficult.
watson said
Good to see the hub caps on, but theres one last bit of chrome to go on.
Tailgate strip Dave?
A product supplied by Accuspark, not quite as simple as they make out a few alterations required, but will hopefully stop the repeated checking and replacement of the points.
You need to set the engine to TDC before you start and remove the distributor. Then remove the points and condenser.
The new kit against the old:
Apply Heatsink paste to the bottom of the unit.
Then fit the Electronic ignition to the distributor. I had to replace the attachment screw with a longer one as the new base plate is much thicker than the points base plate.
I refitted the distributor & the rotor arm and checked it lined up with No 1 lead on the cap. If not, reposition leads in the cap and fit clockwise 1-3-4-2. Which I had to do.
I noted that the plastic disc cover interfered with the unit, so I cut a gap to allow it to fit.
I then realised it needed a bigger gap to allow the advance to work.
The original LT lead from the negative connection of the coil is connected to the negative lead of the unit. I had to use an inline connection.
The new red lead is connected to the positive connection of the coil. I had to extend the supplied lead.
I fitted the cap and started the engine. Reset the timing with a strobe and by rotating the distributor until TDC lined up.
I note that there are plenty of guides on YouTube for this modification.
Had the first nice long run on Saturday from Romsey to Worthing to visit my daughter / grand daughter, also took the opportunity to visit VW Heritage for the first time at Shoreham. A total round trip of about 140 miles.
Pretty pleased, it ran very well. Though in hindsight as I write this, I might take the plastic disc cover out of the distributor, as you have both mechanical weights and vacuum advance systems rotating the unit inside the distributor and the gap I cut might
have to be bigger.
Ive been pleased with the kit as the car starts and idles smoother and it revs a lot better at the top end.
I did feel that I was being a bit restricted when I put my foot down at speed. Under light load it was OK.
Maybe the gap wasn't big enough to take both vacuum and mechanical weights advance.
You can simulate the vacuum to see the plate turn off the car, but you can't simulate the mechanical weights going out.
It has been a few weeks since my last post, the car has been back in the spray shop getting the doors realigned, roof and C pillars polished and some paint touch up, caused by me, after the rebuild.
Whilst the car has been away I been working on the upholstery. Only done the headrests and a seat base so far, pretty happy with the results, but time consuming.
Some time back I purchased a sewing machine, slightly heavy duty. I have been putting some oomph back into the seats.
A few pictures:
The head rests were stripped, washed and new foam added:
Original seat base.
Sprayed with glue, as well as new foam:
Stuck to the seat:
When dry the foam is coat for the metal tension wires.
Cut a long story short, addition foam inserted in the middle section and sewn to create the "panelling". Seat material added to the base foam us via the tension wires.
Started the seat back, can't remember how it came apart !, I will work it out.
So I got the car back on Friday, very happy that the activity is now complete and I can finalise everything for the AGM.
Some pics of the alignment: Needless to say, I am pretty happy.
Since Friday, I have also timed and set the Carb mixture and idling using a Colortune to resolve a hot start issue, it was running too rich.
I replaced the console gauges and the passenger door handle to maintain the one key opens all.
to be continued …………..
I can't wait to see it in the flesh again at the AGM
Here is my trusty stead purchased 18 months ago, used it for the first time 2-3 weeks ago, only three needles broken so far!.
Just to confirm, there is plenty of hand stitching as well!.
Drivers seat base fully fitted to the frame:
Here is a comparison of the new and old drivers seat bases:
Passenger seat base, note a couple of vinyl repairs on the side:
The drivers seat back with new foam inserted and stitched:
Drivers back with a new support mesh. (I could have used the existing one):
Sorry, missed a photo here fitting the fibrous sponge, (might be able to insert one later) before adding additional foam to the both drivers and passenger seat backs:
Seat back cover fitted and assembled to the seat base with head rest:
Fitted in the car, this shows how flat the rear seat is: this will not be done for the show:
Anyway, reasonably happy, stitching not perfect, only I know!, I have passenger seat back still to do.
The wife is away for two weeks looking after the grandaughter whist the daughter is on Jury Service.
So plenty of time on my hands to work on Gary, I mean cooking, washing up, ironing, etc.
Enjoy your domestic goddess routine
I have been looking for the next project, my future son in law wants a mini, but this has been put on the back burner.
Some body is giving me a GTI engine so this might fill the gap for the moment.
I am in Cumbria at the moment on urgent family issues with my father very unwell. GarytheGolf is in Romsey with a front passenger seat to be assembled and fitted.
I have the tickets and the T Shirts but I have had to cancel the Hotel.
Hope you guys have a very good weekend, I look forward the seeing the pictures.
