GarytheGolf
GarytheGolf
MK1CRAZY YAHOOOOO!!!!!
Though not directly associated with the hatchback, I could have stored the wire with the hatchback stuff when I dismantled the car.
A couple of pics showing that some blue trim has been installed. The original trim re-coloured.
The hatchback has been installed the wiring and wash tubing connected.
A little clearing out to allow the car to come back in.
Last edit: by Malcolm
daniboy123 said
Did you work out how the wiring goes for your heated screen yet? If so would you mind taking a picture of what goes where as im at the same stage as you and will be getting the body shop to fit the headlining, cheers.
Hi, well I checked out the wiring myself and checked it with a multimeter. You have wires for the rear wiper motor and a wire for the heated screen both earthed with a common earth.
The little wire shown in a previous picture, though coloured for the heated screen, has been determined to be the short wire between the rear number plate lights. I have yet to prove this.
Not having the headlining at the moment is a blessing in disguise because the car is coming back without it fitted. With a bit of luck, I may be able to take photos during next week, if not, on Saturday, when the car comes back. Hopefully I can verify it all then.
I bought it a few years ago, not sure who from. It was made for me using my old one as a template out of thicker than normal material, apparently this makes it heavy and difficult to stretch, after a while it would eventually sag.
The sowing lines are marked with pencil on the facing side rather on back/wrong side of the material with tailors chalk, when stretched the pencilled stitching lines are visible.
When unpacked it was very creased because it was posted in a packet and sat for a long time on top of my wardrobe. I am told that headlining is supposed to be rolled rather than folded for transportation. The use of pencil has also stained other areas of the headlining when it was folded.
So I have put it down to experience and bought a new one.
A few issues, the sprayer was unable to finish polishing the roof and the rear of the car, due to having appendicitis. He had an operation last night. Polishing will be completed later.
Door / panel alignment will also be redone later after adding all the glass, etc.
Back in his home for the next few months. Terrible picture!
Home comforts though! watching Flog It.
Some work done today:
Filler neck and cap:
Removed the old exhaust and new one fitted:
Engine needs cleaning of dust.
Gary sealed off from the rest of the workshop.
I bet you're glad that you had already detailed the engine, that's one less big job to worry about!
My headlining to due for the 19th, a critical item as it is preventing windscreens and other stuff being installed.
Also discover my NOS windscreen chrome trim is very coiled / twisty. A little time in the airing cupboard no doubt.
The spray shop will fit it all when it' available.
I have now got to find all those loose bits I have hidden somewhere!.
Unfortunately, I won't be able to work on the car for a few weeks. We are off to Cumbria next weekend with my two daughters and new baby to visit my father, brother and sister there.
matt
I only managed two days working on Gary over Xmas.
It's times like these when you wish you had done a bit more recording how thing things came apart.
Some simple stuff fitting the back lights (NOS) and badges:
The not so simple: had a real problem assembling the rear wiper mechanism.
Spent one day putting the glass and seals into the front doors, spot the deliberate mistake: Remember its a GL with chrome:
Having realised my mistake, on the second day I worked on the rear doors.
The scrapers are still to go in.
Yes it's surprising how quickly you can forget how something came apart, done it many times!
Easy mistake to make on the chrome trim The car is looking great and it's nice to see it start to come back together again.
I've probably asked before but is there a 'D-Day' for when it's back on the road again?
