G60 Conversion
jacktimo said
Going to be a awesome build when finished. Best of luck with it sir
____________________________________________________________
__
WOW Gold|Wow Gold Kaufen|Diablo 3 Gold|Guild Wars 2 Gold
Thanks buddy.
I made a loop and attached a bolt to a gearbox mount. I then put the loop over the bolt and through the teeth on the flywheel. Had no problem removing it like that.
RichG said
Just to help other people out with the flywheel removal. I got some washing line cord (steel wire with a plastic coating).
Nice tip there Rich
Nice tip there Rich
Thanks buddy, I was rubbing my head thinking what I had to hand. I thought my impact driver would be a bit savage for the job.
Also what rubber bushes will I need?
Rich
I would also be interested in the recommended rubber mounts to use.
Are you planning on adding power steering?
paulm said
Hey Rich, I'm just starting a 20v project as well. Race ya!
No going to keep it standard. I dont mind it being heavy
I guess 256mm would be safe, not sure about clearance with 280's.
Can anyone recommend a good set and where to get them from?. I have seen some Willwood 4 pot set-ups for around £550.
Last edit: by Rich.
Paid £500 for mine and although i haven't used mine in anger yet I haven't heard a bad word from anyone who has.
What sort of budget have you got?
RichG said
I have about £600, are hi spec anygood?
They're very well thought of from all the research i did when i bought mine.The next step up is the 280mm kit details of which can be found HERE.
Can't see why the 256mm kit wouldn't be sufficient for the MK1 in all honesty though.
One thing I was unsure about, in the advert it says:
please state when ordering 76mm or 94mm lug centers?
I'll try that one Rich, still got my DMF to remove also.
Love your car mate, she's a beauty, It's going to be one sorted mk1 by the time your done
Thanks chap
smudger1980 said
Hmm can't remember off the top of my head what mine are mate. I am sure someone will be able to answer that for you mate. Failing that give the seller a quick tinkle
Have Mk1's got 76mm lug mounts?
peterg60 said
looking good m8 i like your golf gunna be nice with a 20v gud luck with it
Cheers Pete
As soon as I know I will order up
