G60 Conversion
Last edit: by Rich.
I wanted to line up the pipe work so got the charger bolted in but all I can say is Whaaaaaaaat…..
The radtec pipe work was not quite right. The Plenum to the lower intercooler pipe seems OK if not wonky but the supercharger to the top intercooler pipe is a joke. In the pictures I experimented with a 45 degree bend (spare from bartek kit) as the 90 degree just wasn't working. I seem to be missing an alloy straight pipe from the charger as well. The output from the intercooler is 60mm and the pipe I have from radtec is 70mm so its a bit loose lol.
The radiator hose at the top is also confusing as you can see from the pictures I have 2 90 degree bends and 2 alloy joiners lol
If anyone has the radtec kit I really would appreciate some help as the instructions seem to be wrong, perhaps they were for the earlier version of the kit
Last edit: by Rich.
Got the rocker cover and idle valve cleaned and acid etch primed:
Before:
After:
Rocker Cover:
Distributor:
Last edit: by Rich.
Is a work of art!
Fitted my oil cooler kit, tucked the radiator down at the bottom but not lower than the front lip angled slightly towards the ground.
Got the aux belt on and tensioning parts.
Attached the blanking plate to the charger. I was planning to add a boost return kit from bartek but unfortunately there is no way to fit it between the radiator and charger. After speaking to Matt at only charged dubs he reassured me that it will be ok to do. He said not to add anything except oil in the charger every 1k.
Finished with the top coat on the rocker cover, needs a wet sand and lacquer to finish her off.
Finished painting the gearbox components
billet alloy Oil catcher arrived
Last edit: by Rich.
Last edit: by Rich.
Got the lock washers ordered up from VW, should pick them up next week and get the master cylinder fitted.
Put final coat on isv
Lacquered the Rocker cover:
Ran a brass brush over the throttle body to remove the aluminium oxide, fitted the gasket and torqued up the new stainless bolts
Last edit: by Rich.
Smudger
Got the final bits ordered up, boy this project has cost some I'm too scared to look at the receipts!
More progress. I've put on my new wheels with sensible size tyres 195 x 50 x 15's. I need to swap over the lips on the RM's to match the fronts then put new tyres on.
Fitted my jetex exhaust and very happy with the fit. Got some stainless steel wire and welded both lambda bosses on. One for stock narrow band sensor and the other is for the wideband lambda for the AEM AFR meter I have Bought a SPA dual oil pressure and oil temperature gauge to go with my VDO boost gauge. I hope they don't look too out of place together but I plan to replace the vdo gauge in the future with a SPA boost / water temperature gauge.
Hydraulic clutch is working and located the reservoir in the scuttle panel.
Installed the 9 inch servo and 22mm master cylinder and plumbed in the brake lines but will need to remake them as the front lines are a little stretched for my liking and I need to add an inline brake light sensor.
Fuel Rail is installed with injectors and loom.
Connected the speedo cable and rev counter cable.
Things left to do: Fuel lines, electrics and boost pipes
Last edit: by Rich.
golf1980 said
Yeah it's looking great man keep it up
Melteddrummer said
Nice work Rich, she's looking great and coming along nicely!
Cheers guys,
Will be back on it Wednesday to finish the fuel system, just waiting for some wire so I can sort out my 044 pump
MK1CRAZY YAHOOOOO!!!!!
Beeno said
Great build man. Everything looking really nice and shiny. Top notch.
Cheers chap
