First car, First project. 1.3 driver!
(In Topic #183330)
first big challenge after buying was getting it home as conveniently the radiator hose sprung a leak half way back, after a quick fix with some tape from a local diy shop we finally made it back.
Here is how it currently stands from the ebay pictures.
its a solid car, but it needs a lot of work
updates to come
- Fresh
Last edit: by Fresherrrr
steveey said
Perfect base this lad! Awesome first car too. What's your plans for it?
well its Just had new oil and filter, its sitting on 4 Brand new Yokohama tyres on BBS 15" alloys, Aftermarket exhaust, Lowered on coil overs. has Recaro Mk3 colour concept front seats, no rear seats, Sony head unit but no front door speakers, Cambelt and water pump has been done recently too. there is also a servo where the boot lock was, so it open with a button on the dash, bit of rust mainly on nsf wing (rest of body is solid) apart from minor spots.
the brakes are a bit lazy so need a service. there is no headlining, parcel shelf and carpets need replacing.
the plan is too get it in a good running order, so new rad and hoses, new brakes and pads, new grill as some damage is present. then get it tuned up as something isnt quite ticking over correctly, it runs but you can feel something not quite right. then a good clean up and some tlc to the bay and may replace the wings as they don't line up. the passenger side door needs some attention as it only closes if you put your back into it. once everything is mechanically sound i will start on the looks, hope fully get the small chrome bumpers for it, then things like the headlining, parcel shelf will go in, i need to source a back bench seat, which i will get reupholstered in black, i also hope to get some original front seats and get the same done to those too. carpets and door speakers needed new too. i probably forgot a few things but you get the gist of it.
Welcome to the club.
Matt
