Driver, to 16 valver, 2017 rebuild!
(In Topic #97786)
I've had my mk1 since I was 18 (2004), brought with some birthday money for £500 from Stroud in Gloucester, my dad drove it home while my mum drove me back in her car. Many comments on it having poor brakes from my dad, which I would soon grow used to. The car was found by a very good family friend who used to work for Autotrader taking photos for the magazine, (remember those days!) He overheard a guy talking about it in a petrol station in Stroud and mentioned I would be interested. Unfortunately he passed away a few years back, and this has made my mk1 even more special to me.
It was originally a white 1300 driver, but I never took any photos of when I brought it back…
From 2004 to 2006 I carried out some welding and had it painted Mars red (apart from the bay) ran FK collies and R10 ronal turbos, and a Peco big bore 4! It was my first car and daily driver. I never used it as much as I should have because I was either hungover on the weekends or too worried about leaving it anywhere!
The car was then off the road for a year or so, when I had a standard mk3 cl (the only car I've ever sold!) and then my mk2 8v 90 spec gti, (current on a roll over jig..)
The below photo is around 2008, and the start of my 16v conversion - Of course I thought I would have it up and running in a year
The donar, 87 mk2 16v gti
Getting the lump out
Last shot with my trusty 1300 lump
1300 on it's way out, Note home made engine hoist on wheels
1300 out,
Cue cheesy pose with engine…, note home made engine crane, fully mobile on casters
Cleaning off the muck, ready for welding then paint
Stripping the 16v head
Taking the valves out etc, with my modified compressor tool
Cams, tappets, etc out
The bottom end in pieces
Stripping it down on the stand
Crank, great having the engine stand for this
Crank out, I've sized the journals, and there is minimal wear, so gonna order the standard bearings etc
Next up is re welding the engine mount and a few other bits, then get some paint in the bay, the engine has been sent away to the machine shop, so waiting to get that back to.
Will keep you updated
Hope you like Cheers
Pete
Last edit: by chortle
keep up the good work,
will be watchin!!
Member 125 - 2005
Gotta hav me brews in my mk1 mugbigdave said
looks good! lovin the mandatory haynes mk1 mug on your roll cab! :wink:
Thanks for looking
Pete
I have some more pics of the progress so far…
Cut the rubbish riveted in plate repair to weld in a plate
Made a template out of card
Welded this in, with another smaller plate on top to strengthen it more, was a pain to weld the first plate in, it kept blowing thro', but got there in the end, not the tidyist job, but it will do the job.
Then on to the drivers side engine mount, cut the old one off, using spot weld drill which i broke, then used normal drills and brute force
Straightened the mount out, and bent it to fit in its new position
Then welded it in
Also put some patches in where the splitter mounts to the frontpanel.
Also welded up where the mount used to be as i had made a hole
Picked up a gti steering rack, thank you mark
Then i picked my block and head etc from a local company.
Block has had it top face skimmed, and has been re-bored to +.5mm, over standard (81mm is standard), so there is plenty of meat left on the liners if anything goes wrong, oh and cleaned and painted, tho i will paint it red.
Cylinder head pressure tested, skimmed, and valve guides checked over.
Crank had the journals polished just to take the oil marks out, as the wear was minimal.
All new bearings, thrust washers, and pistons to suit.
The new pistons
Also have all gaskets, seals, oil stem seals etc.
At the moment im prepping the bay ready for paint, so will update soon.
Cheers for looking
Pete
Have you managed to get hold of the other gear linkage parts?
Whats the next job,building up the engine?
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
mark83 said
Coming on well Pete.
I may have some bits lined up but still looking at the mo, plus i have some Q's for you :scratch:
The next job is prepping the bay and spraying it, then on to rebuilding the engine which should be fun
Im thinking of putting the ecu inside so need to sort that out also.
Pete
Keep up the good work.
i,m very glad you've the patience to not only carry out the task
but to document it too!!
you mentioned gti rack and some gear linkage parts, am i missing something??
still waiting on my box turning up so dont know what i need yet?
i,d better find a rack too if necessary!
looking great though buddy!! keeping a close eye on this thread!!
cubed said
doing this very same thing myself at the moment..
Yea im using the gti rack and gear linkage bit as my mk1 is/ was a 1.3, so the gear linkages are different 4 speed to 5 speed, and they also mount onto the rack which the gti rack has a mount for, and the small block rack doesn't.
Just search thr'o the many build threads here, and on other site like club gti, your soon get list of parts up.
Paul C, i will be using k jet, by ecu i meant the kjet ecu thingie.
Pete
I need to sort the fueling stuff soon, as far as know yet i will need,
Cab lift pump, for the 1.3 fuel tank, (as it's not a gti tank)
mk1 pump and accumlator, and the pressurized mk1 fuel filter
Various pipes, and some home made mounts
Oh and fuel lines, still undecided here, may have custom ones made up, as metering head is the other side to a mk1 gti setup, so don't wont to cut up a brand new set of lines up.
So much more to do :roll:
Pete
paul_c said
I assume you mean the 16V's ignition ECU? There's no value putting the ECU inside, it sits nicely in the scuttle tray and the wires for the coil and TCI are all there.
Yes thats the one, was going to look at putting it inside to tidy things up, but if it's a pain to do i wont.
Pete
