Buddy MK1
1983 Pirelli Edition
Love the colour mate
Keep up the good work
Design Manager
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
Daft question maybe, but is there any danger of leaving the blue tape on so long - i.e. not being kind when it comes off?
Mk1_rich said
So while im still waiting for it to come back from paint I have managed to get a few more bits cleaned up, painted, ordered etc AN fitting welded to the inlet mani new 90* fitting to go on said fitting rear calipers and carriers, starter motor and front engine mount painted SuperPro mushroom bush fitted to front mount New OMP lower front brace More parts bolted back onto the block. Alternator bracket, alternator, shorter belt, belt tensioner, oil cooler couple of pics from the body shot. Front panel now had a few less holes Rear inner arched cleaned up
where did you get the mushroom bush from?
83 MK1 Golf 1.3 CL
Design Manager
Here you go…
http://www.golfmk1.co.uk/Details.php?item=SPF0527&group=ENGINEBAY&cat=SLAREA
Last edit: by Joe90k
matt
would you advise it to someone who hasnt really got a clue about wiring or would you just get someone to do it,
Hairyarse said
Great work, this is going to be such a nice car when it's finished.
As the paint is still pretty fresh I removed the tape to let the paint breath and dry better. As long as you are careful when removing it you should be fine.
I got my complete kit from Jamie at J Tech Automotive. Really helpful chap.
Neil20vt said
love the engine bay mate, how hard was the loom to do ?,
Well, I felt the same so sent mine off to a company called Vagtronics. Again, really helpful guys and a very quick turn around. They added in a fuse box and fuel pump relay and removed anything that wasnt needed.
Having looked at it, it really wouldnt be hard to do yourself. The only problem is it comes back the same length as you sent it. So if you want to do a loom tuck/ tidy it up a bit then you have to do that yourself which thankfully wasnt a problem for me.
1983 Pirelli Edition - http://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=view&id=165792
did you go for the immobiliser defeat only are did you map too ?
Matt
