AT LAST! Hairys Resto!!
First off however, the last personal update for Chris Massbad69 - sorry mate, they're all gone
So I've finished welding the A-post end of the sill;
…and there's a split in the repair panel that needs welding in the lower front corner which is split during pressing. I had to balance on my head to weld it so the front facing camera on my phone came in handy to see and take a pic to ensure it was all done ok.
One sill-selfy!
I also had a revelation when I remembered a tip that Yomp has posted up before about welding up blow holes - or holes in general. Take some copper pipe, slit it and flatten it out into a flat copper sheet, and clamp it behind the hole as below (but preferably tidier than mine! )
Then weld the hole up - the weld wont stick to the copper;
And seen from the rear after welding;
Top tip Graham - thanks for that one!
The only job left to do in this area is to weld in a small piece onto the door aperture/seal flange so that it meets up with the sill properly as the sill repair panel didn't extend up to the radius.
I'll just make a card template from the other side and replicate on steel for this side then Bob's your Dad's wife's sisters husband!
I may take Friday off to work on the car when it will be grinding time!!
I'd forgotten how stiff they are new, I could barely use my wire cutters on the mig wire!
I then made the smallest repair patch I think I'm ever likely to make! It was for the door aperture flange to finish the curve off
It was so small I didn't finish the shaping until after it was welded in to place;
I then filled some small holes on the inner sill adjacent to the top sill flange then spent an hour and a half grinding, first with a flap disc then with a sanding disc. My arms are dead and I'm still not finished!!
Hopefully can get it done this arvo - there will be some tight spots I'll use my new air tool for but still waiting for some air tool oil to turn up before using it!
After all the grinding, lead loading is on the menu for the first time!!
Melteddrummer said
Looking good Andy, you've got a fair bit done! I'm sooo jel of your new grinder ( I might have to copy )
Don't be jealous just yet, I don't know for sure that my compressor will run it yet!!
Well I've now finished pretty much all of the grinding on the off-side this afternoon, which I'm sure my neighbours will be pleased about!
In grinding the welds back I had a few pin holes and bits to tidy and add a few welds here and there but all in all I'm pleased with it. Just about ready now for some lead solder, filler and primer. Just need to attend to a few tight spots with the mini grinder or Dremel
This rear corner will need the most body solder I think;
Last edit: by Hairyarse
Power tools, what are they….. lol
Wanted: Front Bumper, DESPERATELY NEED A DRIVERS WING!
MY Build Thread
My Facebook Build Page #Project83
Looking forward to pictures of the lead loading.
Andy - don't forget I've got that depression above mine, so it's not over yet. Cheers for he compliment though
pazwaa said
Looking good, getting close to finishing
I don't know about close! Discovered today that the gear lever and accelerator are both seized solid so that's another couple of jobs to sort!
I'm looking forward to having a play with the lead - I hope I can master it
Chris
Massbad69 said
Good progress Andy but the project should be on hold until the biscuit tin is restocked !!
Chris
I went hungry today!
Well Andy Melteddrummer all I can say is if you're ever going to get a boner over an air tool it will be this one! It's so useful, really cracking tool. My compressor kicks in after about 20 secs of use and doesn't stop but it keeps up with the oomph.
I feel like I've got nowt done in the four hours I've been on it this morning, but then have had some more little welds to put in and general tidying - just takes a lot of time I guess. I've just stopped for a late lunch then back out there. Have to grind the welds under the filler neck panel in the side trim groove then I think that's it! I don't think I'll get on to the body solder today but if not will skim some filler on the bottom of the A-post to see what that looks like.
The story so far today;
This mini grinder has been excellent for getting in to those awkward spots. It doesn't feel heavy when you're using it, is quiet and not too aggressive so you can get good control on cleaning up welds. It does grind surprisingly quickly too. It gets a from me
Also did a few bits on inner sill and sill flange to smooth the welds out
I've not used filler in over 20 years so wasn't a bad first stab! Far from finished but thought I'd have a little go with the sand paper before calling it a day
Next on the list - more sanding
