AT LAST! Hairys Resto!!
Hairyarse said
Thanks for the advice Graham, that's spot on
Out of general interest, should you ever apply zinc primer before welding, or only to areas not accessible after welding is finished? So far I've been zincing everything I've been welding thinking it was the right thing to do
It's fine to apply the paint before to all surfaces as long as you remove it again before welding. The Idea is to get paint in all the areas that you can't once welded, if that makes sense. You're doing it the right way bud
Well I got a couple of hours in tonight and a few more welds. I'm still struggling on all welds to keep the two panels flat together even with clamping close either side of all welds. I think the issue is when I cut the outer arch off, it's just on the start of the radius where the arch curves in to the body. If I had cut it on the flat part of the arch (in profile) I think it would be much easier.
Hence, I've been spacing my welds but not completely evenly as have been welding where it will clamp flat - or appears to at least
Not much of a pic update - just the same as yesterday's really but with more dots on it!
What I'll most likely do once I've finished it if I'm left with a fine gap between panels - and it is small - is line the edge with body solder before laying down any filler. This way I hope that I'm not filling a crack (oo-er!) and running the risk of filler ever cracking out in the future.
Oh and two of my welds are out of whack, I missed the join between the two panels - didn't realise until I lifted my visor!
zorg said
if you havn't done so already you can use an air line to cool down your spot welds, but as others have said move around the panel rather than on one area.
-z
Good tip - I'd forgotten about that - I have a compressor too!
Honorary Member
<a href="Pictures by campaignjerry - Photobucket"><img src="http://i286.photobucket.com/albums/ll103/campaignjerry/Reworked-LogoRight.jpg" border="0" alt="Photobucket"></a>
I did turn the wire speed up just a smidge yesterday - about half a point - which made things a little better too.
Regional meet tomorrow for MK1 and MK2 clubs but Sunday should be back on it, will carry on with this whilst starting to prep the OS sill and bottom of B post repair for welding.
If I do all the noisy work Sunday then I can weld in the evenings next week without annoying the neighbours!
campaignjerry said
Well done Andy !!…I'm looking forward to progress with great interest.
Cheers Jerry, hope before too long I can be bombing down the A1 in it to come and see you
Honorary Member
Bert said
when is the diesel engine going in hairy?
Bert
Ha ha! Er, never! 8V GTI all the way for me, it's a sound you can't beat
I ground the welds down on the arch, didn't go crazy or put too much heat in. Then thought I'd start off getting the OS sill to fit so I could weld that during the week.
However, whilst I have two sill panels, they've both been stored in my garage for about 8 years and are peppered with little rust spots on the outside. Also I'm not happy with the quality of the panel. The step in the panel just above where the sill trim fits isn't anywhere near as pronounced as the one on the new arch panel, so I've decided to order a new one from VWH.
Even if the step isn't any better at least it wont be rusty!!
Plan for the week - more welding of the outer arch
Thought my build had taken it's time lol…. Some serious determination and learning invloved on this ..
Not sure i'd have the balls to do any of that myself, fair play..
Keep it up bud!
Alfie
Wanted: Front Bumper, DESPERATELY NEED A DRIVERS WING!
MY Build Thread
My Facebook Build Page #Project83
Blowing holes is a frustration still but overall it's satisfying getting this done. Just hope I can get it done for the AGM now, that's all
Ok, a pic then - not very exciting though lol
Oh and my new OS sill turned up from VWH today. Much better quality overall than the two I had and it's longer at the A-post end which will help. However, the 'crease' in the panel above where the sill trim goes still isn't as pronounced as the arch repair panel so I'll have fun sorting that I'm sure
My sills were the same mate, just had to blend them in as best I could
Andy, when you say you had to blend yours in, in what way? With filler? Hammer?
