AT LAST! Hairys Resto!!
It is quite pitted Paul - will see what occurs next weekend but get the feeling I'll be chopping some of it out :roll:
chudd said
Progress looking very good Andy
Cheers Nige, trying to get it done at long last!
Another point about wire brushing pitted metal is it only removes the loose rust, the only way to get down to good metal is with the grinder. having said that I think a splash of rust eater after a wire brushing is as good as anything.
Greg
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
Hairyarse said
Ratchet - how much to hire the welder? Will it be as cheap to buy a mig? And will a spot welder do all the repairs you need?
Been quoted ?30 for one day, ?45 for two or ?65 for a week. Probably have to leave a hefty deposit too. That's just from checking HSS and the like.
It won't do all my repairs, no - but it will do the rear panel and sills better than I could with a mig.
Decided to bite the bullet and remove the chassis leg on the near side. Haven't finished tho…
Glad I did, metal underneath looks solid but I don't think the leg itself was too tidy. Is a real pain to remove but hope to have finished tomorrow. Cut off the exhaust hanger/hook and kept to weld to new panel but will be checking with VW first if you can still buy. I checked on ETKA and it does have its own part number. (Can hope anyway!)
Not sure if will get rear panel on or not tomorrow though, not too much free time! :wink:
there is probably a better way of doing it but that was all i had to hand.
you doing a cracking job so far. keep it up.
Tom
Just want to get the car sorted now so pushing on as quick as poss. Feel like when I have the rear end done, that will be the worst of it - we'll see! :wink:
is there a repair panel for this section? mines gone in a few areas and will need some work
mike
1983 1100 C
1983 1100 C
Got as much of the NSR chassis leg off that I wanted to.
…in readiness for the rear panel 8)
^^^^^^^^^^I really should tidy up under the car now!!^^^^^^^^^^
It's only trial fitted at moment - I ran out of time and have some further 'fettling' to do but next time should be on and finished - can then do rear chassis legs and work around the arches, sills and then that's rear end done!
Sounds quick and easy but know if wont be - oh and filler neck panel repair….. :wink:
