Alpine White G60
Yomp said
Fuel pressure reg problem? Pressure too high? Can you fit a guage in line with the fuel rail or try another reg?
Mk1 golf g60 unwell - YouTube
RichG said
Hi George try running with the lambda disconnected. Check all the wiring to this is OK. I had a similar problem with my 8v g60 corrado.
Also what ECU are you running? Digifant in your 16v g60?
If so a worse case scenario is the injectors drivers have gone in the ECU due to a bad earth.
Try the lambda first, on mine the earth lead snaped with age and caused those symptoms.
Rich
i took the plunge and i got an ecu off eBay and gave it a shot..
we now have a healthy running g60!
This is how i found the lambda wiring…
i never touched it as it ran in the car it was fitted in so i assumed it was correct. Looking at it, the signal wire isn't even connected. Ive unplugged it for now, could this have burnt out my ecu?
also here is my new ecu.. supposedly it was chipped, it looks standard too me can anyone confirm this?
i removed the motorsport gear shifter as it just doesn't look right in the car, unfortunately i have to remove my exhaust to fit the new shifter as i want to fit it from underneath for a more factory look so il do that when i next have a chance
anyone for a motorsport shifter?
then hook it all up and test it out
mounted the new tower in today, dont think the reverse light switch will go in without butchering the plastic end, how have you guys done it?
once i convert to hydraulic clutch i guess it will give me a little more clearance once i cut the cable bracket off
when the cable bracket is bolted in the cables dont point in the correct position, not sure which is the offending part tbh ignore above, i have the bracket facing the wrong way, we have gears, deffo needs a short shift and an extension for the gear knob with this setup
Last edit: by G60RGE
Got the extension from just campers, its the only one i could find in m12 x1.5, looks good but would prefer if it was straight
also fitted the audi tt short shift, because of the long lever it doesn't really feel like a short shift though, it just feels normal which i will live with.
ps ignore the blue seats their time will come
I've been making some progress with this.
i rewired my lambda so thats all plugged in and it runs much better and doesn't stink soo much at idle as the ecu isn't chucking in loads of fuel anymore
also finally got round to making a top radiator support as it was tied to the slam panel with wire
only a few small jobs left before its ready for the road like standard mot friendly headlights taping up and heat proofing the wiring loom and gear change cables and checking oil levels. oh and i insured it for the first time since 2012
Matt
but I'm snowed in
Are you going to reinstate the VIN rain tray panel as well?
im hoping to start a new trend here…
its not going to be an easy task to make it look legit even though it is
its not going to be for sale anyway
looking for a very good body shop to undertake this close to north london if anyone has any contacts
