4 Doors for more Problems
(In Topic #206094)
Pictures Pictures Pictures
As of 20/02/2016 I became the owner of a MK1 golf CL. Now if I had any sense I would have started the build thread then but here I am a little under 5 months later.
So the fun all started on viewing day. The car was advertised as a runner; this however wasn’t 100% true. Other than the fueling issue everything else was as stated. We bargained with the owner and got It for a steal.
We loaded it up on the trailer which turned out to be a mission in its self, I’m not sure who designs ramps for trailers but they must be regular mountain climbers. when we finished dragging the bottom of the car up the trailer we set off home.
We chucked it straight in the garage where I spend half of my life T-cutting it to try and get some shine back in it. Aside from the orange wing and door its not looking to bad now, especially for the what I believe to be the original paint
We got the thing running by patience and some tinkering, the fuel seems to be running back to the tank when its left sitting for a while (suggestions on this would be appreciated) but also from the the timing was out and as was the idle on the carb
Then come the modifications
I’ve always wanted something on bags, so I wad of cash and 3-5 business days later they arrived. By this time, I had the car stripped ready to fit. I originally thought it would be a massive ache to install air ride however its essentially just coil overs with some air line going to them.
I’m wanting to keep it all clean looking so I spend ages thinking of ways to do the install. It was only when the tank was sat on top of one of the wheels that I realised it may fit into the spare wheel well, so I pulled out the spare and to my massive surprise it fitted a charm. we cut a board for it all to be mounted on and chucked it in. a bolt goes through the drain hole and bots up so the whole lot doesn’t get ejected through the back window when I hit a bump. We are yet to make a false floor for this to be hidden with, I’m hoping cut some planks and stain it etc.
The next problem are the switches, they come in their own little housing which is nice but I don’t want to be cutting to the car to mount it up. I decided to put it where the clocks are in the GTI’s when I pulled the center section out and found out that there are already cut outs behind a faceplate. We cut a few circles out of some plastic we had lying around and mounted the switches in these and I think it looks awesome
It went back on the floor after being jacked up for what was probably coming up to 3 months and it was low but the front was still a bit high, after some inspection it was sat on the driveline. After some convincing I talked my dad into doing a chassis notch for me (I know structural integrity blah blah)That all went great and is lower now but still sits on the driveline so I’m thinking we will take another bit of this out over winter. We also cut out the arches to stop things rubbing and give us a little breathing space, the rear ones will be done soon as they rub too.
I picked up a set of BBS Rm’s off eBay for a good price and they are immaculate, they look pretty snazzy on there too, a little photo of it half way up and all the way down
That’s pretty much it for the mean time I’ve probably missed a lot but I’ve started all of this at a bit of a silly time
Feed back will be amazing as I’m not mechanically minded
fuelling issue-wise, I've got a 1-way valve plumped in to stop any chance of fuel draining back to the tank on my system, could be an idea? (not sure about carb'ed systems though, mine is fuel injection)
Matt
Love the switches by the way, nice job that and many thanks for sharing.
Lucky your air install fits inside the wheel recess, suits it down to the ground (no pun intended ).
Theres not been much since my last post just been busy enjoying it for the time being
I went up to Bug Jam in July, the car never skipped a beat there or back much to my delight and surprise (even with 3 people and enough camping gear for 6)
Then I went down to VW action, saw a few people who I believe are on here, nice to see some other mk1’s (got papped there trying to be a show car)
Then I had my first breakdown in her, while delivering some cake tins back to my nans. The seal on the rear air bag came lose and wouldn’t let me air back up. Aw well at least the car wasn’t moving anywhere haha. Got this sealed again and has been fine since *touch wood*
Since then I’ve attended a few local meets and ultimate stance so have a few glam shots from that
I’ll try post more often! Maybe..
Simple and clean, love this! I think I need myself one of them blinds too
