1984 1.6 GL
There was only the tiniest dusting of overspray on the rear window, it was mostly just mucky on the inside so that cleaned up quickly and well.
The side windows had heavier overspray on them, but not as bad as the windscreen. They too came up nice and smart for the most part.
There is some minor damage to the drop windows in the doors most likely from badly fitted scraper clips. One bit I can't understand is this strange mark in the centre of the driver's door glass, it's almost like it's been shot blasted and had an attempt to polish it smooth afterwards, there's no contaminant in the glass as one might expect with welder or grinder spatter.
The weather broke when I'd done the windows, but held long enough for me to make a start on the bodywork proper. Although the car has been washed twice and given a work over with cutting compound I hadn't yet treated it to a claybar so that was my next thing to try out. I was surprised that there was more overspray hiding under a sort of stubborn rough film of dirt on the front wing and even more surprised at just how well the paint came up once I'd cut through it all back to clean paint.
I managed to make a start on the bonnet too. You can see the finished polished section on the right. The rest of the bonnet is clean but it doesn't have as crisp a reflection and looks a different colour purely down to the amount of dirt and overspray still to remove from the panel. I'm not entirely sure what has caused the plethora of dents on the bonnet but my current theory is that it played host to the annual Little Persons Tap Dancing Contest. At least it comes up pretty shiny enough to detract your attention from the damage.
Then the heavens seriously opened and I called it quits for the day.
I'll keep plodding away at the overspray removal just like I did with the black paint on the interior and before you know it I'll have a Golf that looks careworn rather than neglected.
I'll keep plodding away at this, I know the bonnet is the worst panel on the car so it'll be pretty easy once I've done that.
From the pictures I knew the stuff would need a clean and a bit of tlc here and there, but nothing that was beyond my skillset. We met up with the chap selling the interior who was thoroughly decent and had a poke around his very early phase 1 GTi cabby that's awaiting restoration. The interior I've got is left over from two other cars with brown interiors that he'd broken and were surplus to requirement. I was surprised at just how many differences there are between his very early Golf and my fairly early phase 2. Turns out those brown hinge/seat trim pieces I'd got were a luckier find than I realised as the latch mechanism for the roof changed in 83/84 (my car being an 84) and the locking latches move from the roof frame to the seat trims, had I collected a pair of phase 1 trims they wouldn't have fit my car.
I've also been able to determine that originally my car had a cream roof and that the black one must have been a replacement at some point, this is from colour combinations and the corner trims on mine being cream. I may be putting a cream roof on after all, we shall see. Of the items he'd got out of storage, only two weren't with him when we went to collect: passenger door card and front carpet. Normally, this would have bothered me but since we found out he had other trim pieces he'd be happy to post on with these missing parts and the fact that he seems like a thoroughly decent sort I gave him the benefit of the doubt and look forward to the bits arriving in the near future.
What I got was a nearly complete phase 1 interior that replaces pretty much all the missing brown trim in mine.
Front seats and seatbelts (I'll explain why the belts as well in a moment), rear bench, rear carpet, parcel shelf, parcel shelf side trims, 1 front door card, both rear door cards, window adjuster toggles and wiggle bits, door release handle trims, door arm rests/closers and some dead Ford speakers. It's a pretty good haul for the money. With the exception of the driver's seat side bolster, all the foams are in good order and the frames are nice and solid. The fabric is only saggy because the stitching that gives the centre panels their unique shape has gone probably just from 30 years of bums. The damage to the fabric on the driver's seat can be conserved and I already have a plan of action to sort this out, all of the dirt will shampoo off fairly easily and they should all come up very nicely. I may end up swapping the seat foams on the front seats to balance the wear out and make the flat spots less obvious, if they weren't folding seats I'd just swap the seats and belt clasps side to side instead.
So, those seatbelts. On the phase 1 there's a different belt system to on the phase 2 and every other car I've ever seen. Instead of having half the lock on the seat and the other on the belt, VW fitted an unusual all in one lock on the seat. You pull the belt around, hook it on the chrome bar and push the bar down to click the belt in place. A press of the release button releases the belt. One advantage I can see of this is not having to fish around for half the lock when it inevitably drops to the bottom of the belt.
Other than that, the front seats fit in the same way as far as I can tell thus far. Unlike the back seat. The upright of the back seat fits exactly the same as the phase 2 but the base is quite different. Instead of a central locating tab and two tabs at the front that screw down to the bodyshell that the phase 2 has, the phase 1 has a peg on one side that slots into a hole in the bodyshell which is present on my car and a sort of ball thing on the other side that I presume should slot or lock into something but on my bodyshell there's only a dimple. Once it's in place, the seat feels secure enough, but I need to find out just how it should fit properly.
Then it started to rain again so I chucked everything in the car. I've got out all bar one door card of the old interior so that is in storage ready to be bought and collected by the interested party to offset the cost of the brown interior and later I'll get the rest of the brown interior fitted that I can. The front seatbelts presently fitted may well end up being used as rear seatbelts in the Princess, but I've not decided yet.
This is the door card I have, for the price of free I'm not complaining at all about it but due to water damage it could do with a new backing board to make it tip top. The speaker hole is modest enough to allow me to fit some smart period looking things as originally these didn't have front door speakers, apparently.
At the moment I want to get everything fitted to highlight any issues I might have - none so far beyond the back seat base - before I do the cleaning and repairs that are needed. Should be nice and easy to clean it all up too, it's nice to be working on an interior that isn't hideously grim.
Still hunting for the right fabric to retrim the phase 1 seats with, found a few that are close but none that are perfect yet. I'm using the Princess pretty much all the time though, the Golf and I aren't getting on like I thought we would and while I'll get it sorted and looking good I don't know if it's going to stay with me long term. We shall see.
However, I am still going to be connected to this particular Golf and am still slated to complete various jobs on it because my brother has taken it on instead and plans to go a similar to route to the one I was taking.
So at the moment the Golf has had its roof stripped down and the interior is waiting on a retrim pending the final seat facing colour my brother wants to go for. The engine seems to have responded well to my brother's tinkering and runs better than I got it to.
Not going to be a quick job to get it through an MoT which was my plan, instead my brother is stripping most of the car down and rebuilding it with a view to getting it back on the road no earlier than next year to ensure as many issues as possible are resolved.
I'll keep this blog updated with progress as I find it.
Smudger
Love this car to bits so glad my brother let me take it on. The engine was only so smokey due to rubish oil or whatever was that came out of it …. looked more like watery marmite. Have the roof frame up for grabs if anyones interested but the removable bar at the front has a small bend in it on the left side and the headliner too which looks ok.
Also hi to everyone I only just joined forum
Smudger
The roof is coming along well. Built on the original frame with a fibreglass skin and now building the form and knocking back to get it into the right shape. Lots of work still to do, but it's getting there steadily.
I'll get a side profile pic at some point. I'd mentioned the crashy stuff, here's what's happened. You can see the chipped indicator and the slight deformation of the rear panel.
The light unit got pushed in at the bottom, which has made the top pop out a bit.
This is the worst view of it, the paint has come off back to the galvanised metal on this corner. Everything still works, but it needs straightening and a complete new light cluster because it's broken all the fixings. Bumper moved back on its adjustment and jiggled straight so at least it doesn't look too bad now.
Life Member
