Hydro oil reservoir for mk1 cab
(In Topic #236732)
Hi, anyone have one for sale or know where I could source one? Just need the plastic reservoir.
I bought on of these, which I believe is for a mk3. Part nr 8G0898101:
https://www.ebay.com/itm/203532645743?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=9jfQ6rrERPC&sssrc=2349624&ssuid=bt0D5N1VTn6&var=&widget_ver=artemis&media=COPY
I don't think the mk1 ones are obtainable.
It works perfectly, it is just a bit deeper so you have to measure were the level indicating marks should be from the old one. I also had to slightly bend the mounting bracket where the reservoir rests but was pretty easy.
Thanks for that! Makes sense regarding those levels. Will see what I can get my hands on.
I had looked at the mk3 one, looked similar but i think that lays down flat so marks for min n max will be out, probably have to fill it by sound.till it sounds like there is enough in.
Regards Volkswarren
I just measured the marks' distance from the open end of the reservoir on the old one and marked it with a permanent marker on the new one. That way the level will be the same on both in relation to the pickup.
The angle of the pump on the bracket remains exactly the same.
