abf ecu...
(In Topic #159583)
hi .i think my ecu has gone pop. been looking for an early abf siemens ecu non-imob type but noughing about. little bit stuck now. thanks r
hi. cheers dude. i was running an early 92 unit without an imob, might go this way though and use the security system to my advantage . thanks for the heads up. r
No worries mate, hope you get it sorted.
Hi there,
I have an early Abf Ecu I'd be willing to let go for 90 posted.
It currently has samco red silicon hose attached to the Map sensor as I was fed up with the braided vac hose perishing all the time.
hi, yep I'm still looking for an ecu. did you know what the serial numbers are ? just to cross ref a little i have siemens 5wp4 201 . vw 037 906 024 G. thanks r
I know for sure it's an early one and i'll grab the serial no. for you tomorrow
If you go for the later one make sure the ignition chipped key is included
Part number as promised and its the early Ecu with the AB at the end of the Part no and If I remember correctly the one with the built in Imob is the BE ended part no.
I know mine is the none Imob for sure as I sourced it along with the Engine some Years ago for a conversion of which it was recently removed to make way for a 20vt Here's the part no for You to reference 037 906 024 AB -Siemens 5MP4 133.
hi . thanks for the no's . looks like what i need . providing its runs good, I'm in . so cash wise pp?
No problems it runs fine especially with the decent Vac Hose fitted.rico said
Only removed the Ecu and Engine for something different and even questioned why I removed it mid conversion lol
Drop Me an Pm with your address and ill get back to You with My PP details
Edit unless your local'ish i didn't think to ask were Your located I'm in Warwickshire.
Last edit: by golfmadness
