Swallowtail rookie joins!
(In Topic #207665)
Rookie found a swallowtail
I'm a real rookie when it comes to cars. However, as a sailboat owner and DIY fanatic I am used to fix things on my own. I have been looking for a project car to be converted to electric vehicle and for some reason I like German cars. Obviously I have been looking for Golfs. Last week it just happened a mk1 1975 swallowtail was found in a barn and I bought it! Now my job is to restore this nice piece of German automotive history and I promise I will be asking you a lot of stupid questions… Still in the barn:
Does anyone have an idea whats the color of the car? Rallye yellow?
Out at the field. She will need some love before back at the street:
The VIN is 1763075203. I guess this means the car is from between Oct.-Nov. 1975 based on Dan Reids Swallowtail.info website. Does anyone know is Dan still around? Tried to contact him with no success.
The engine is 1.1L. Anyone interested to purchase it?
Best regards,
Antti
Wow very, very nice barn find that.
Keep it standard!!
What's the interior looking like?
Here's a couple of pics of the interior:
No idea if the Pioneers are original. Probably not.
Service manual was also found Note: keys still in the lock!
She has defrost in the rear window. Is that original?
Dashboard was in pretty good condition although very dirty. Note the button with small sticker "TAKA L…" it has typo Should be "TAKALASI" . Meaning rear window.
I will post more pics once I have her cleaned up
Cheers,
Antti
My car has an element that goes into the engine block to defrost it and that plugs into the main house electrics. It also has a plug socket fitted to the interior which I would imagine was used to power an electric heater to defrost the car as well.
scottyr1 said
Wow great find, please don't make a swallowtail electric mate
Hi! I respect this comment. Let's see if the engine is still running. If it runs I will for sure rethink. I have to get it properly checked first before I try to start it…
However, the electric drive and all of its components would fit under the hood very well. The interior and outside would be kept original. Only thing changed would be the engine. Looking outside one wouldn't know the drive is electric. The conversion would be done with full respect to the originality.
Cheers, Antti
Its an extremely rare beast you have found, and I agree with scottry1I beg you not to do the electrical conversion to this particular car as whatever you do it will never be the same again. Preferably get a later mk1 or mk2 and do you bit on them instead. Sell this car to someone who will restore it to its original condition if you can !
I would love to buy it- but that isnt the reason for the above- ! Its just that its in such good original condition considering its age and rarity it would a terrible shame if having existed like this for all these years it was to become converted..
Please think about this.
Marcus.
After careful thinking I have made the decision to keep this car original. I can not argue with the fact pointed out by Daytona. I will keep this yellow-beast original and get another project for the conversion
Now I just need to learn how this 1.1L works. Any suggestions how to most carefully try to starting her up?
Cheers, Antti
Check, clean plugs and points, adjust as required.
Inspect air filter, clean or replace.
What's the condition of the oil looking like.
Check charge battery and replace if necessary.
Most likely the petrol is old so drain and replace with a few litres being careful not to suck up the gunge at the bottom of the tank.
Water level of course.
Then just see if she fires up and runs on tickover for a minute or two and then stop and start checking the oil and water.
Just what I'd do to start with but as I said I'm sure others will think of different stuff! 👍
With mine I added some fresh oil and set up a gravity fed fuel line at the fuel pump.
I knew my fuel filler knock was corroded and the tank probably had rust in it as well so set it up like this to miss out the fuel lines.
My carb needs setting up properly that's why it idles high in the video
https://vimeo.com/185452682
Gti bumpers, or did base model 1100's come with non chrome ?
Good news are the engine spins (tested by hand). Electricity works (pressing brake shows brake lights etc).
I have done extensive cleaning of the car inside and outside and changed some smaller damaged parts (like rear hatch struts and engine parts etc.)
Now when we finally have decent temperatures in Finland I can really start some work over the project (I have a cold garage at the moment for the car so the winter was quite silent regarding the project)
Best, Antti
looks a nice find and I'm glad you are keeping her standard.
I agree,
fresh petrol, do a full service on the engine before starting, all belts, oil, filters etc.
I am recommissioning a swallowtail too. I also used marvel mystery oil in each cylinder to help the dry rings have something to move on and use some in the oil to help get the old dirt out.
Once it running check the electric fan and radiator fan switch are working, you dont want it to overheat and blow a head gasket straight away!
Your 1100 is 48 HP @ 6000 and 79nm Tq @ 3000.,which is as much as the vw beetle had from a 1600, so with the low weight it will get along fine.
Last edit: by Keith Usher
Long time since the last post but good news! I have activated restoring her with the help of my son.
The Swallowtail is running ! Special thanks to Daytona who has been helping us a LOT! Short review what has been done so far:
-New plugs and leads
-New filters air, oil and petrol + petrol hoses, oil change
-All fuses, light bulps etc small stuff
-Flushed the petrol tank with water, acid, sod. carb. , water, ethanol, petrol (previous owner has apparently changed to notorious filler hose) so there was only little rust in the tank.
-Carburator main jet blown clean and correct adjustments made (to keep it running in idle)
-Small radiator leak repaired using "radiator seal". Maybe change to new radiator in future.
During the test run I noticed the brakes are very weak. I have been reading brake upgrade posts and that is probably the next thing to do together with installing new seat covers and passing the legal inspection for her. I'm asking her the so called "museum plates" we have in Finland.
Does anyone have good condition mk2 16v gti brake servo and master cylinder for sell? Looks like she has neither of those. I would also be interested in aircooled brake discs.
Best, Antti and Lenni
