Bonnet Stuck shut.
Hi all, i'm new to the site. Please can anyone assist. My bonnet won't open. Cable seems to be attached. Even with grill removed i don't seem to be getting anywhere. I,ve sprayed the bonnet catch with WD40 but do you have any other idears please. I need to get it open asap.  I don't really know what i'm looking for. Thanks. It's a MK1 Cabriolet.
That's odd because with the grill off you should be able to get your fingers up there and release it.  :(
So I'm giving this post a bump because I'm sure someone will have a better idea then me!  :thumbs:
Maybe time to get flat bladed screwdriver give it a hammer to loosen. Like mentioned earlier normally comes free. With fingers.
On the drive
Myvalver 89 GTi Grey mk2 16v
i assume your grille was off before you had this issue… O_o you should be able to see, easy enough, where the cable goes into the 'catch' & move it/push it to the right as the catch is spring loaded… perhaps a slight downward pressure on your bonnet when you do it.. :thumbs:
sometimes pressing down on the bonnet as you pull the release works.
Regards Volkswarren
X2 1983 A REG EW CAMPAIGN In WHITE(Awaiting full rebuild solid body) :thumbs: & T Reg S1 GTi Project, Still Looking for Series 1 GTi's or a 16S Oettinger to restore (Complete Cars only)  or an A reg Lhasa Green or White Gti to restore, also consider  Black, Red or Blue, Also Golf Driver Project Wanted anything considered WHY
