Will my engine fit? Help!
(In Topic #120061)
not sure I'll have a look it has all of the pulleys n pumps on the left and gearbox on right I'll have a look tomorrow
to be on the safe side I'd fit 1.8 8v 210mm clutch and find a 210mm flywheel from 1.8 MK1/2/Scirocco
It dropped straight in had to swap flywheels and manifold,it's running fine it's a good engine quiet and smoothe no rattles or knocks or smoke.it cuts out on tickover I haven't had chance to get an air filter it's running with the empty airbox don't know if this could be the cause? It's a bit lumpy ticking over so needs a tune aswell I think… This is my first engine swap so any advice would be good
as long as the cable works its no big deal, to do it factory you would have to swap all throttle linkage for a manual one then fit a manual cable
