What engine should i go for!?
since_1983 said
400 pound you could get a complete donor car that would be my 1st line of attack on this
Even if you buy a 16V Mk2 Golf GTI, you'll still need the conversion exhaust manifold and system. It should have most of the parts though, and some of the remaining car left to scrap/break.
If doing a 2.0 16V, it will either be KE_Jet or EFI on the ABF. ABF is a tall block and limits your choice of exhaust manifold, also there's issues with the throttle body touching the bonnet.
Plan was to recondition the engine before it goes in definately. New gearbox is a must (unless I can modify my current 020 to work with it). Engine bay was fixed up a bit recently (steering rack mounts rewelded).
As for the other parts I'd have to collect them slowly and surely when the money and the items are available, but relistically, judgine by the amount of things I need to get, and also the amount of things to change on the clipper, it may not be economical.
Like you say, if I want to do this, either picking up the parts second hand or finding a good cheap donor (which kinda negates the need for me to buy the engine seperately anyway?). Could I use the suspension and brakes off a mk2?
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
It may be that I look into just fitting a k-jet system on my current 1.6 for the time being while keeping the engine swap for another day (or another car! sounds like I'm probably better starting off from a GTI).
Downster32 said
Why would I need a new fuel tank? Surely I could modify the old one to have send and return? That would be cheaper surely? Or do you think it would be easier to fit a new one?
What year is the car? If its newer than about 1985 you can use the same fuel tank but fit a high pressure fuel pump external to it. If its a hatchback, then you do this; or fit a GTI tank and sender. There's a few different variations of how to do the fuelling.
How about the gearbox? What gearboxes do people usually line up to the 9a's?
I'm going to do this engine conversion, and I'll update you as I do. Phase 1 is parts collecting. If I can get the parts I may convert my 1.6 to injection while I'm waiting too.
Cheers for your help.
Jd
paul_c said
All these guys who want the same engine conversion but haven't gotten round to doing it themselves - do you want me to do the conversion for you???? My rates are very reasonable…..
Do you fancy this one mate? If I get all the parts how much would you charge!??
Definately interested in the 1.8 option…..I'll keep you posted. We'll see what I can get my hands on.
I mean, my car doesn't have the original engine in so I have no problem with making it 'un-original', and like you say, a 2.0 16v is very involved. If a 1.8 is very straight forward swap I will investigate it further.
I really want to do the 2.0 for the challenge of it, but the more I think about it, for what I want (cost effective better cruising, more reliable running) a 1.8 (or even just sticking to the 1.6 and injecting it) might be the answer….your views?
but theres probably a more complicated set up or something - the mk2 8v will definately fit straight in so is it worth the effort finding a mk3 8v :dontknow: the price of a donnor will probably be higher.
