Mk1 20vt wiring
Hi all, it's probably been covered a fair few times! Does anyone have any links for a clear step by step guide to convert an Oem 20vt loom into a mk1? I can use either mk1 or mk4 clocks which ever is easiest. Rubjonny has been in touch previously but his links on his page don't seem to work now.
Using an AGU
His links need to be updated I think mate due to switch over to the new forum. PM him he will be able to send you the links that work. :)
Cheers Andy he's sent me some before but to be honest I can't really make heads nore tails of them. Need them in simplton terms!
I paid £250 for mine to be converted with an ECU deimmob. Came back labelled up ready to go mate. Well worth the £££.
I should of done it i know. I'm impatient and his waiting is months now from what I've seen! I've already had the immob delete done at r tech.
I got mine done through a contact of JonP's. Got it back in 3 weeks. Top job. PM me if you're interested and I'll get his details for you. :)
read this thru till the end:
http://www.clubgti.com/showthread.php?205887
agu can be a bit different on the coloured/t14 plug depending on the age
