agu mk1 wiring questions???
it looks like the sender is right next to where the speedo cable goes into the clocks?
ill grab the clocks from the car tonight and see if i can switch it over!
i remember trying these clocks in 1 of my other cars and the speedo read the wrong speed (there 140mph clocks which would b a bonus if they'll work! :punk: ), is this something i could fix with the correct speedo cable or is it a gearbox issue
the speedo issue would have been down to the gearbox having the wrong gear in it most likely
the mk1 clocks do have a space for the vss and the same connection on the pcb so iv fitted the sensor in place on the mk1 clocks and connected it.
im hoping the other bits this sensor needs are already provided from clocks.
think im gona try and connect the signal wire to the pcb (theres 1 wire form the sensor that just ends) to see if that will work
http://www.telematicagroup.co.uk/companies.php?supplier=US-07&manufacturer=MSD_Ignition&cat=MSD_10_Accessories&category=Accessories&sub_cat=MSD_916_TachAdapters&sub_category=Tach_Adapters&view=list
maybe 8910 or 8920??
thanks
good find on the price.
rubjonny said
have come down in price since i last looked, good news.
my question is should i
use a larger amp relay, like a 30
use a separate extra relay?
i think i have the fuel pump, injectors and 1 other thing being supplied by the fuel pump relay
thanks
and a 33 ohm resistor inline brings the coolant gauge down to about where it should be!
been fitting a couple of things inside the car and i could do with an ignition live, wheres the best place to get this from?
i have used the stereo one before but its not there on my current golf!
just a few more bits then off to the dreaded mot. . . :mrgreen:
theres deffo fuel comin from the pump and its cranking,but im at a loss and starting to think i have broke some thing!
Any ideas!!!
but its still not running right but i have a few fault codes now
injectors1,2,3 and 4
whastegate bypass regulator
these both go to the fuel pump relay pin 87
along with
mas air flow sensor
and o2 sensor go to here as well
but there is no fault for these two
could i have damaged the ecu?
would a fault code reader tell me this?
is there any way to check this yourself?
im at a total loss because it was running just fine before it was moved!
this is how things are wired into the car but im sure somethings wrong somewhere
+ its not got a standard fuel pump (think its a fse jobby) not sure if this makes any difference!
