Suggest some engines for me
I'm picking up an abf engine and gearbox on Saturday which is pretty local, will I be better to us the box already on the abf or my existing one (which is nice and smooth etc)
Wouldn't hurt having the gearbox from both to choose between them in time to me…
020 gearbox come with all kinds of ratios, so no worries there if you want taller look at 2.0 8v for sporty but slightly more relaxed over mk2 gti, or a diesel/driver one if you want really tall gearing but it might blunt the feel of it a bit.
But to get cable change can be costly.
the only thing thats easier when using the 02a box is you dont have to kink your custom made downpipe around a gear linkage, because there isnt one the 02a is cable shift, so you can just route the cables to avoid your downpipe.
the trouble is the downpipe fitting on the standard 16v manifold is further over to the passenger side than it is in a mk1, so your downpipe starts too close to the linkages. so you have to kink away from the linkages to avoid them, then kink back a little bit so it lines up in the right place to meet the tunnel.
without the gear linkages, you just have to move the pipe across a bit to the tunnel
I've found someone who has offered to do some welding anyway so I'll probably just make one up
My next question is what should I be doing to the engine/box before I put it in? I'm planning on doing a decent service and clean, but should I be taking it apart and replacing internals?
Exciting stuff, can't wait to get started now!
the first thing I thought though is have I bitten off more than I can chew? Looks very daunting!
how many hours roughly will this take a competent home mechanic?
