Driver door needs a bit of a slam to shut properly?
(In Topic #158561)
Do I need a new latch?
My drivers door needs a bit more force to close properly otherwise it opens partially which can get really annoying and I don't like having to slam it so much. Does it seem like a problem with the latch? or could it just do with being refurbed in some way? its only the driver door which i assume is down to over use
Thanks,
Matt
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
COTM Team
Is the door sitting straight? How are the panel gaps around it? Also, check whether the bottom or top corners of the door are catching and rubbing on the sill or top of the b-pillar when the door closes..
My mk1 tin top's the same and I've always put it down to solid build quality! Too much pressure inside the car as the door closes. Mind you, the passenger door's the same.. I put the window down a little and the door shuts with a precise thunk!
Let us know how you get on!
Website Manager
COTM Team
Good to hear moving the pin a bit has helped.
