Do I keep my head up
(In Topic #93300)
2. nearside (outersell) seat belt anchorage prescribed area is excessively corroded
3. Front (pipe joint) exhaust system has major leak of exhaust gases
4. nearside front (floorpan) suspension component mounting prescribed area is excessively corroded
5.
6. Offside (steering rack mounting bracket) steering component mounting prescribed area is fractured **dangerous**
7. offside front (floorpan) suspension component mounting prescribed area is excessively corroded
8. offside rear (innersill) suspension component mounting prescribed area is excessively corroded
9. offside front (strut tower) suspension component mounting prescribed area is excessively corroded
10. Nearside front CV joint gaiter split
11. Nearside front suspension arm corroded and seriously weakened **dangerous**
12. Offside rear (strut tower at seam) suspension component mounting prescribed area is excessively corroded
13. Nearside rear (strut tower at seam) suspension component mounting prescribed area is excessively corroded
14. Offsice rear (inner arch a joining sill) suspension component mounting prescribed area is excessively corroded
15. Nearside windscreen wiper not operating automatically when switched on
16. Offside windscreen wiper not operating automatically when switched on
17. Nearside windscreen washer provides insufficient wash liquid
18. Offside windscreen washer provides insufficient wash liquid
19. Windscreen has damage to an area in excess of a 10mm circle within zone ?A?
20. Reg plate lamp not working
21. Offside rear (innerwing) seat belt anchorage prescribed area is excessively corroded
22. Nearside front (innersill) seat belt anchorage prescribed area is excessively corroded
23. Nearside front (floorpan) seat belt anchorage prescribed area is excessively corroded
24. Offside front (innerwing viewed from under bonnet) suspension spring mounting prescribed as excessively corroded
25. Offside head lamp not working on dipped beam
26. Offside heaplamp not working on main beam
27. Nearside headlamp aim to high
28. Exhaust emissions carbon monoxide content excessive
29. Offside (outersill seam) seat belt anchorage prescribed area is excessively corroded
30. Offside (outersill seam) seat belt anchorage prescribed area is excessively corroded
31. Offside front (floorpan) seat belt anchorage prescribed area is excessively corroded
32. Rear (mountings) exhaust system has amounting that it does not fully support the exhaust system.
Advisory Items
1. Nearside rear (inner wheel arch) ) suspension component mounting prescribed area is excessively corroded but not excessive
2. Offside front suspension arm has slight play in a ball joint
3. Nearside rear brake disc slightly pitted
4. Offside rear brake disc slightly pitted
5. Nearside rear and Offside rear box sections very heavily corroded
6. Additional corrosion and holes in boot floor
7. Corrosion at off side inner sill
8. Addition corrosion at nearside inner sill
It sounds like almost every area you can fail for corrosion, you've been failed on - so the car realistically needs a full body restoration. To know if its worth it or not, we'd need to know if there's anything special about the car, etc. So, what's the spec? Is there any sentimental value attached to it?
Can you weld? (I'm guessing not…)
Ive wanted a mk1 since I was14ish im 23 now an didnt think to look under the car
The car was on the road and was without an MOT for about a month.
The shell in good condition and it has the spec as follows:
1. 8v
piper cam
lightened pully
lightened flywheel
perfomance spark plugs (triple platnum)
perfomance HT leads
full exhaust system
koni suspension 30mm
its mechanically sound, and im really gutted.
I can weld but not the bet, or though the about needed doin I think I'd end u half decent.
Any Ideas on what to do?
The other thing I can think ofis that the previous owner was getting dodgy MOt or something?
I'd never sell a car with that many faults, and I'd feel bad about selling a car with MoT but then went on to comprihensively fail the next one. Obviously if there's a few minor faults, that's part & parcel of an old car. So, fair game on the electrical faults, worn ball joint, split CVJ gaitor.
Maybe even the engine is worn? Is it simply out of tune or does it have a more serious issue, to fail the emissions? And how much did it fail by?
The Gti is my first and it is also the one in the sig
83 BBS MK1 GTI 69 T2 PANEL VAN i am back let the trouble begin
gazmorgan1985 said
erm yeah gonna start rstripping the car today so i'll keepy you posted…if i buy rear inner wings' arethes the ones which hold the suspesion in…
Nope!
What they describe as 'inner' rear right wing, is in fact a panel which sits in the middle. AFAIK the curved panel in the boot, is not available. If you have an area of corrosion around the right rear seat belt mount, its a tricky (but possible) fix to make a curved panel to replace the corrosion. I did it, and I have a thread on here somewhere showing it.
golf mk1 shell
Ray
in all honestly id strip it save the best parts for your self and get another one like paul said and put your best parts on that etc and sell the other parts on.
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
<a href="
<a href="
