2.0 16v ABF Conversion
(In Topic #158617)
Apologies for the undoubted repost.
I have decided to sell my GTI engine and go ABF which looks easy enough, I think, but can anyone tell me or give me a link to a 'walk through' or similar to help guide me along the way?
I have looked but can't find one.
David
Last edit: by wannabemk1owner
MK1 Golf - 1.3l Driver
MK1 Golf - 1.8 GTI (Build Thread - Here)
http://www.clubgti.com/showthread.php?133418
rubjonny said
Cheers John
One thing im stuck with though is clutch cable, im using a self adjusting seat one from the donor, seems to work fine appart from fitment at the bulk head, what do you guys use?
crezz said
John is a legend, helped me along the way
I second that
Will my 1.8GTi box fit on an ABF lump?
wannabe: yarp, but you need to change the clutch kit for mk1/2 gti 8v 210mm unit and use a 1.8 210mm flywheel
as for clutch cable, ive found some other hefty rubber bungs I was going to use on bulkhead followed by a big washer to spread the pressure.
the pedal is stiff tho, not sure how you get the cable to adjust though?
if its an old one you might find it no longer works!
thanks again bud
