Oil pressure light flashing
The connector has two little finger clips on it that you unlatch, and they allow the "lock" part of the connector to flip back or up and all the pins are loose.
The problem may be that as was stated the low pressure light is in the speedo, and that is connected to the mylar. If there is no input to the warning unit, then your lights may do strange things because of the floating signals.
Do you have the CAN pressure unit on the side of the head? Oil pressure / Low oil pressure. I bought a new one and it gave me fits until I moved it to the Spare port on the oil filter flange. I used the Block off and placed that in the side of the head.
It seems to be if he's laid up for any amount of time he likes to Buzz as us. After a week of constant use by Lady Borednow he's decided to stop. I wonder if it's moisture in the guages themselves and just through use it finally dries out.
Apart from keeping and eye on the oil level I've wiggled a few things and checked contacts but nothing worked.
Sorry I can't help, but Yay for Clive!
the big one on the filter housing should be white, 1.8 bar with a blue/black wire. this one is responsible for then light and buzzer if pressure drops when revs are at about 2k rpm and above.
If you earth the blue/black wire that should shut up the warning, if it does look at the switch and check oil pressure. if not its a wiring or clocks issue
fingers crossed its just the switch though
