Drainage
(In Topic #240463)
to the left of the screw driver is what a pucker drain looks like.
Look under the car on the seam where the rocker panels
meet the sub frame, and if you take your door cards out with the speakers and regulator then look at the bottom, clean all the garbage out of the bottom with a vacuum and you may be able to see them from above.
I use the end of a cable tie to clear mine out.
