Battery light staying on
(In Topic #239053)
Light staying on even when exciter wire is unplugged
As you state that you have a furbared plug, The plug should of been 3 pin with one of the pins being the exciter, and the other two going back to the battery +
One wire is blue the other two red.
As there are repair connector ends out there. It could be that your exciter wire got broken at the connector or a few inches back.
Do the 12V jumper first if that doesn't turn the battery light out, then you need to have it tested.
I've checked the resistance of the exciter wire from the alternator right back to the fuse box and there is 0.2 ohm resistance, this would rule out the wire to this point.
Only thing is, regardless of it the exciter wire is connected or not, the battery light stays on as soon as ignition is switch on, also when engine is running.
I've tried 2 instrument clusters and they both have the batter lights staying on.
Any other ideas, or could I have issues with both clusters I'm using?
I would test it for continuity to ground.
The exciter wires starts at the cluster and runs to the alternator.
since the main 12Vb+ comes in to the cluster on pin 14 black, then it goes through the LED parallel resistors and then the diode, so if you don't have the exciter plugged into the alternator, then what is the voltage on the exciter plug on the alternator at this time.
So years ago when the Alternator was added to cars, they (used to be generators). They are cheaper to produce. The major differences between them are Alternators produce Alternating current, they use a voltage regulator/bridge rectifier to take AC and convert it to DC.
Since we know that the idiot light or battery light in the cluster gets it power to light from the battery input on the black wire from the cluster. Battery power comes up through led through the 2 parallel resistors and the Diode in the cluster, then goes over to the Alternator.
to tickle the field coils and starts them to generate 13.75-14 VDC.
Since the battery is at 12V current flows through the led and diode as it is forward biased turning on the light.
When the alternator has started to generate power, the Exciter post goes more positive, as in 14V. Since this is more than the 12 that lights the led (battery light) the Diode in the circuit becomes reversed biased, and turns off the led, normally which isn't happening in your car.
With the car ignition switch in the Run not started position, what is the voltage on the Blue wire in the cluster (disconnect it from the alternator for this test).
The whole circuit for the battery light, doesn't have a ground reference to it. It uses the Alternator as a negative source to allow current flow through the led, and diode in the circuit to light the LED since this is feeding the alternator 12V to start it charging, then as the Alternator starts producing a greater voltage 14V it reverse biases the diode at the top of the led in the circuit not allowing current to pass turning off the light.
Diodes are represents as a single line and a arrow pointing to the line or triangle. The way that it points is in the direction of the flow or the negative side of the
diode. 12v and go up the diode (looking at the schematic as up the page turning it on as the exciter side of the alternator normally isn't at 14v or 12, it is negative to the led so that is why current flows through it.
I would suggest at this point as you have used 2 clusters, both showing the same thing. That you take your Alternator off the car and have it tested, as I suspect that your voltage regulator or Bridge Rectum Fryer (old joke in electrics) has some issues as in one side of the Bridge may be bad.
If it tests ok, this would leave the Fuse box as the issue
if you have Water migration may have caused corrosion and Bridged something to the exciter. circuit as the traces in them are really close.
Dang we are getting too deep in this.
Do you have the Bosch flat voltage regulator with the Plug or the external mounted regulator with 2 wires.
Old type internal regulator Alternator (motorola over hear on this side of the pond) 2 styles that I have seen
External mounted Voltage regulator no plug just 2 lugs.
Most latter Cabriolets used these, but early Golf, Rabbit, and Cabriolet as in 77-82 early over here use the plugs or (internal regulators).
Take the Alternator off and have it tested.
Last edit: by Briano1234
Alternator along with engine, is from a 2000 1.8t mk4 golf.
Fusebox is NOS and completely mint, I've got a spare so will throw that on and see what happens. Appreciate your help, will let you know what I find.
I then unplugged it again and gave it 12v feed and again the light goes out. Now the strange thing, on my car when I give the exciter wire 12v with it disconnected from the alternator, my wipers started to operate 😳.
Checked both blue and yellow plugs on fusebox and can confirm that the blue exciter wires are in the correct locations. I'm stumped!
Mk1dubber said
Problem found, Luckily I had another loom, I found the plug on the white loom was slightly damaged, the pin 12 was contacting 12 and 4. Replaced and all good. Thanks for all your insight 👍🏽
Good find, glad to be of an assist.
