Door Hinge
(In Topic #225411)
Excessive Play
Door check repair 1
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2F-83-gti-set-to-get-full&start=540#post_1354305
Door Check repair2 (cost effective for novice's with lack of welding skills.)
Door Check repair version 2 | Volkswagen Owners Club Forum
Saggy door fix (cost effective and less time to do).
Saggy Door Fix | Volkswagen Owners Club Forum
Now if your seals aren't aligned after or leaking before you adjust or replace be prepared to have to adjust window height, and or door alignment to get the seals to work.
In the signature link below I have a ton of where is my car leaking fix's.
The old school method is to open the door and use a jack and piece of wood to gently ease it up a bit. Do a bit of at a time and carefull close each time to make sure the door catch pin still lined up.
The alternative spanner monkey method is to open door and yank it up with your bare hands.
This door hasn't sagged, its hinge has come loose at the point its welded to the A-pillar.
Rogdodge said
I'm pretty sure there's no play in the hinges, I used a piece wood to lift and lower the door and it appears the A post area that the bottom hinge is welded to has weakened, cause probably rust, this is a surprise to me as the Body appears rust free and the MOT tester as confirmed this two years running. As soon as I can find the time I'll take the door off and investigate.
Have you any pics, not come across this before, it's usually a worn pin or sagging/drooping that can be adjusted back up
It's now fixed..
I'll try and find some pics
My check strap fixing had also come lose, 1st 3 pics are rusty hinge and last pic after repair, the welding is not the best I’ve Ive seen so just hope it lasts and I’ve not wasted a chunk of money and time removing the original wings…
Last edit: by mark1gls
Door Hinge
To tack mine I just removed the door, door light switch and trim around the door opening, covered the hole where the door was to stop any sparks getting inside and ground back the old seam sealer and cleaned the metal with a Dremel type tool to reduce damage and tack welded the hinge, re apply seam sealer and touched up the paint with a brush..
