I bought the wrong brake overhaul kit :(
The end that fits on the trailing arm nearest to the rear wheel is readily accessible, the other end under the rear axle is a twot. You really need to lower the axle which in turn means disturbing the 4 nuts/studs that hold it the car and they have a habit of shearing off leading to a whole new world of pain replacing those.
I would only consider dropping the axle if you have about a week, to do it and wire brush the studs and nuts and Spray with PB-Blaster every day… Then using a Air Impact lessens the chances of shearing the studs and nuts…. I suspect a little heat on the studs wouldn't hurt either.
It is tricky to do but if you are restoring the car I would pull the beam off as then you can remove the fuel tank and check it over/repaint then fit new bushes on the rear beam.
If you do remove the beam clean the threads and plenty of soaking as mentioned above and go very carefully, do not just undo the nuts, losen them a little then do them up, then losen a little more then do them up etc… this cleans the thread because if you just try to undo them the thread will lock up and shear the bolt then it’s weld in a new bolt time…..
I don’t have an air impact wrench so I had to use a socket set.
Last edit: by mark1gls
Last edit: by espenlg
