Timing and misfire 1988 gti on carbs
I'm not happy with the resistance I felt so I'll have a look for more dots etc.
there are more marks/colours on the inside of the pulley.
It's a 1988 car so head should be 1988 as far as I know? I'll take the cam cover off tomorrow and have another look at everything.
Determined to get this sorted though, I won't be turning it over until I've trebled checked it all.
The car was sat outside last week when I was doing it the first time and I needed to get it back in the garage
1988 Helios Blue GTI Cabrio project running 1900cc 8v on GSXR 600 carbs and with added porsche bits
Former Mk1's - 1983 Golf Driver 1.3 and a 1982 Golf GTI with a 1.8l 16 valve sold 1999 - CKC 66X (I would love to know if its still alive…)
Yes and worth taking the cam cover off to check and you are doing the right thing not starting it and turning the engine over by hand.
Sorry 1 more daft question that I've thought about when I woke up.
Am I correct in thinking the cam and crank are to be set to TDC and it is only the dizzy that is set to 6degree before TDC off the crank marks?
I just want to get this right
I had a bit of time before work so I've whipped the cam cover and cambelt plastic off and checked the valve positions.
The cam was at least 180 degrees out.
Found a line on the back of the cam pulley which tallies with the cam lobe to pot 1 pointing skywards
Does this look right now
I think the cam gear being on backwards possibility is a bit of a red herring, since its not possible on this engine.
The more I looked at the pulley I realised that, it's offset to one side isn't it.
Just need to put it back together now and see if it has made a difference
Set everything perfectly but the car absolutely would not fire, had to retard the timing about 15 degrees just to allow it to start.
Mechanically everything was as it should have been this time around.
Now to strip the bike carbs install and look at the basics of that to make sure it is all there and then it's off to a specialist tuners.
Its normally "ignition" rather than "fuel", but having said that, on bike carbs (or with K-Jet), its normally fuel!!
Its a bit like a broken clock, its going to be the correct time twice a day…..
So you could get it to start and idle lovely….just no power at the top end (for example).
Regional Host NE
