Solex to Weber 34 ICH
(In Topic #236246)
Anyone know what I need?
Also not sure about your carb but my carbs I had to check the choke size was correct for my engine size and also had to check the jets. My chokes were good but the jets were wrong because my engine capacity is bigger, (bored out)and it's cammed, running headers and big exhaust. I'm also located in USA. You can calculate the choke size (if yours has that) and jet size just by doing a quick search and learning from Google/youtube. Lots of stuff on my specific Webber 45 side drafts, again not sure for your model of carb.
In addition to that you might want to contact a Webber retailer in your area. I'm in USA so I contacted Dave at piercemanifolds https://www.piercemanifolds.com/ and he also calculated the jet size for me based on all the info I provided him with. He was very helpful for me and caught a few things I had missed. I also got an online fuel gauge to check pressure on the downstream side of the regulator and also looking to possibly add a third filter there too as I believe with carbs the cleaner you can get the fuel the better the carbs will run.
I also had to get a manifold specific to the Webber 45 carbs and that also led to proper rubber/spring loaded mounts etc.
Also if you got a second hand carb defo worthwhile to clean and setup correctly and get a good overhaul kit with the wearables and gaskets etc.
Also this book helped with "basic" level overhaul info. Don't see your ICH listed but you might want to find a good book for your carb also.
Anyway, not sure if that helps any but that's what I had to do.
Last edit: by Shubbs
