Screw
(In Topic #227410)
idle adjustment screw
Checked with VW Heritage but no luck.
Andrena said
I am looking for a idle adjustment screw for my mk1 golf cabriolet (rivage). Could you help? Thanks
Are you talkign about the IDLE By-Pass screw that is on the back of the throttle body by the firewall? Or if digi the Idle fuel flow.
https://www.partsplaceinc.com/vw-idle-air-adjustment-screw-23993.html
When going back wrap the threads of the screw and the threads only with teflon tape, it helps seal the threads so when the o-ring goes it still is air tight, and it helps keep it in the car.
