Noisy gearbox
(In Topic #242375)
When the clutch is depressed it goes quiet so defo gearbox whine.
Could it be the release bearing ? I've replaced it but may have got it wrong ??🤷🏼♂️ that would be the easy solution to replace….
If not think I'll have get a recon unit and get it fitted.
It's certainly fought me every step this Golf
Moderators - can you remove two of posts ?
I've a spare out of a 1.8 gti Cabriolet. Not sure if it's condition internally or indeed if driveshaft cup size is 100mm or 90mm - I'll check as could get that checked over/recon and swop it over.
Someone has mentioned an O ring ? Where does this go 🤔 and what is part number. Did look on VW heritage site to see what is being referred to and location of it - sounds like I'm missing this
Looking at the ubiquitous Utube it would appear that the speedo drive comes with an inbuilt seal
Last edit: by golfy1
I'm taking the car to a gearbox specialist in Hull for him to get feel of what problem is by taking him for a spin. Then based on what he says I'll take car home, pull box out and take box to him for rebuild/repair. Seems the likely low cost option albeit it a faff for me.
I can't drive it around as a) too noisy and spoils pleasure b) possible further damage done
If you remove the filler bolt on the side of the gearbox is the oil level with the filler hole?
