New Roof Lining
(In Topic #217510)
Advice
HI guys,
I'm looking for a company to fit a new roof lining on my cabriolet cant seem to fin anyone local. Looking around the milton keynes area.
Check with Carl…chortle if he's able to visit or if you can visit him.
Pretty sure he's got someone he'll recommend if he can't do it.
On the drive
Myvalver 89 GTi Grey mk2 16v
New Roof Lining
Headliner is year depending and it’s the fitst thing fitted to the frame.
So the hood and interliner and pad would need to be removed/replaced.
chortle said
Headliner is year depending and iysbthe fitst thing fitted to the frame.
X3
BUT……………
The last one I did on my car, I seriously gave thought to using Snaps to make it removable in the Future so I could clean it…… but then I thought about it, and I would need quite a few snaps, and I already had everything else being the cheap bastitch that I am I dropped it as a idea gone wrong.
New Roof Lining
Interesting thought but not sure how you’d hold it up around the centre rails.
Plus it’s hung on those straps in the corner.
You’d need a ton of snaps for sure..
Snaps on the flaps to snap it to the cross-bars. I mean they have screws in it at places which I suspect that is why I started to "pop" rivet it to the cross bars as I had seen too many where the glue failed…. I figured at the rear snaps on the back side, and for the bridging strap between the rear window… I mean I gave it serious thought……
3 per bar…. works really great as an augment to the glue.
New Roof Lining
I can see the merit in the thought process.
Really common for the headliner to come off those rails.
I use a High Temp glue.
However I’ve seen folks use normal contact adhesive which just isn’t up to the job.
Nice idea on the rivets though.
