MFA Switch not working
(In Topic #207184)
MFA works but the short term and long term switch doesn't work
Also, the outside temperature doesn't seem to show. I have no idea where the sensor is.
I haven't taken anything apart yet and I'm hoping it is just dirty contacts but if you have any suggestions and if anyone can give me a clue as to why the temperature doesn't show it would be appreciated
MFA has some wires traveling down the stick to a plug behind the steering cowl.
The MFA stalk has four wires coming from it (white, red, black and blue). I have check continuity of the stalk and it would appear to be working correctly. It is also connected to the four pin plug that goes to the MFA. As the scroll switch works I can only assume that it is connected correctly.
I did find a two pin plug that isn't connected to anything in the back of the dash. It comes from the wiring loom and I can't find anywhere it may connect to. Could be nothing.
At least I can tell how warm it is outside now!
red/white and black/white from memory, the plug is the same as what VW speakers use if you know the one I mean
In picture 6 there is the plug you are after.
The instrument cluster is slightly different to my 88 gti as I only have 2 connections, the main big one underneath and the MFA you are on about so I guess there is a couple of different instruments but I recon it's the same as yours as its for a later car.
http://vwgolfmk1.org.uk/index.php?page=cedi&type=misc&id=1%2F42%2F147
Next problem to tackle is the alarm!
