Light upgrade
(In Topic #234277)
Hi I have a 1983 mk1 cabroilet with twin head lights but they don't seem to be very bright is there a bulb upgrade. Thanks...
Hi I have a 1983 cabriolet with twin head lights that doesn't seem very bright . Is there a bulb upgrade that I could replace them with… Thanks for you help …..
bad grounds and you need to relay your lights.
If you take a meter and measure the voltage at the light pins you will usually find between 11, and 11.3V
After relaying you will see 13.75.
They make kits on ebay that are good and fairly cheap.
don't pay over 20 bucks and make sure the headlight sockets are ceramic.
I've used the relay kits on several mk1 and mk2s and can confirm they definitely helped. Couple of hours to fit and you're good!
Ok thanks for your help . Did you get the kit of ebay…?
I have, make sure it is all inclusive as a water proof fuse holder and relays (there should be 2) one for the high and low.
Here I did a search of the uk ebay.
https://www.ebay.co.uk/itm/255059004554?hash=item3b62b38c8a:g:gsYAAOSwbYZg9R0h
This is one that I've used before:
https://www.ebay.co.uk/itm/292804895796
I also ordered a cheaper one at around £11 in May 2020 but that listing doesn't exist anymore. Seemed similar.
Couple of sketchy photos below:
First shows how I installed relays in a 1990 mk2. I added the zip ties because I was concerned the relays might jump out. Probably unfounded. At bottom right see a purple-ish bent bracket that I made to hang the relays from slam panel. Not waterproofed, still working after ~1year.
Second shows same thing in my 1989 mk1 cab. I used some metal strapping to make the bracket. No zip ties or waterproofing and working fine after ~3years.
I could have done a neater job especially with the cable routing etc but it is how it is
