Is my car running too hot?
(In Topic #220123)
Do you think the gauge is not accurate? Or fan kicking in too late?
Thanks in advance!
The a/c system has a 2 speed fan that kicks on any time you have your car in defrost, or blue area of the selector, it has a 3 pronged temp sender on the Radiator, and you have a engine CTS that assists. Depending on your t-stat rating and the switches rating (should be matched) The radiator fan on a 2 speed system kicks on at 95 (no ac on) low speed and 105 it goes to hi-speed. There is also a relay in front of the battery that controls the fan, and the after run fan operation these relays strictly a 40 Amp general relay can go bad.
The are you measuring the water temp or the oil temp? Oil sender is a single pin on the oil filter flange, and the 90 Cabriolets have a black sender on the front engine water outlet that had the black plug (may be brown), where as the CTS sender on a 90 digifant is blue on the same flange with a blue connector.
The normal dub with a working gauge is 1/2 to a little over 1/2 deflection when driving. When Stopped you will see the engine go to 3/4 to slightly below the first hot mark.
Now with a Digital gauge I would ask C or F?
And was your Gauge supplied with a new temp sender?
Gauges are Calibrated to the Sender usually.
230C is 110F so this is why I asked.
230F is 446C so it is tooo hot.
Oil is a different issue, as the oil temp on my Automatic is 110-130C driving about town and interstate prior to me putting on an external oil cooler. Now I can only get it to 110 with the a/c on screaming down the interstate at 80mph.
The Problem with the "in-dash" gauge is a cold solder joint on the wires internal to the gauge. A simple removal of the Gauge and repair will put it back to original in about 2-3 hours depending on your skill set.
I had had 4 Cabbies, 89-93 and the water gauges have all gone flaky… If your fuel gauge is acting up, then I would suspect the connection and or the 10V stabilizer on the back of the instrument cluster (clocks).
Testing your water temp gauge with a 9Vdc Battery and some jumpers. No Ignition Key needed and it tests the deflection to the gauge.
Testing Digifant Water Gauge | Volkswagen Owners Club Forum
Here is a good how-to on fixing flaky grounds and power to your clocks.
Improving your Cluster Connections and ground. | Volkswagen Owners Club Forum
Here is the how do I repair my water temp gauge.
Repairing your Flaky Water Temp Gauge | Volkswagen Owners Club Forum
