Intank fuel pump
(In Topic #221445)
Seen where the pump will run for about 20 minutes over heat, and stop…then cool off and resume for another 20 minutes.
A bad CIS fuel Pump Relay can give the same warning conditions.
On cornering you may feel hesitation, and a lack of power. The interconnect hose for the pump can hole, and or fall off.
Loss of power is another…
Intank fuel pump
Sent from my SM-G930F using Tapatalk
https://www.classic-vw.co.uk/in-tank-lift-pump-191906092a-5174-p.asp classic vw
http://www.golfmk1.co.uk/Items.php?cat=ALL&group=FUELPUMPS crazyquiffs
https://www.vwheritage.com/357906092c-in-tank-fuel-pump-wit-strainer-19mm-vw-spare.
https://www.ebay.co.uk/itm/In-Tank-Electric-Fuel-Pump-For-VW-Golf-Jetta-MK2-Polo-Passat-Cabriolet-1-8-16V/253729021418?epid=2151361217&hash=item3b136d9dea:g:OpAAAOSwqVVbPDyC
whilst doing intank pump, you can check for rust and clean majority out.. my pumps are nosiy to be honest, constant sound, but i do have 1 of each pump spare…just incase .
On the drive
Myvalver 89 GTi Grey mk2 16v
Intank fuel pump
pm me if you want them ill measure them and confirm which size they are.. think 12mm is it the hose or meter head thats blocked? if hose you could remove the blockage wth air or welding wire, if its the injectors thats blocked then you can soak in fresh fuel… to see if work under pressure.
On the drive
I think I have the same issues with my 86 gti cab…noisy main pump and cuts out after around 20 mins
What is the best fix ?
55 going on 15
1984.5-1993 mk1 How to change your in-tank fuel pump | Volkswagen Owners Club Forum
I was thinking it maybe the relay
55 going on 15
